Trying to install a wide band into my auto 32 gtst and have run out of ideas on where to run the cabling form the sensor to the drive unit which is inside the cabin. I don't really want to drill holes in the floor or firewall. There is a rubber boot underneath the shifter for the linkage to the transmission, but this location doesn't appear to be suitable as it could foul the linkage. The other option is from the engine bay through the same route as the engine harness to the computer, there seems to be another rubber boot/ seal there which is proving difficult to guide the cabling through.
Interested to hear how others have routed their cabling into the cabin?
Cheers Mike.
https://www.sau.com.au/forums/topic/428940-wide-band-installation-help/
Pass it with the engine wiring. I use a coat hanger with the end bent back and wrapped in a little insulation tape (so it doesn't tear anything up too much) as a guide rod to poke through, then tape the wire(s) I need to drag through into the cabin onto the hanger and drag it in. I have used method that to pass through wiring for and air-fuel meter, a pyrometer, for the IC water spray, and so on.
  • Like 1
I ran a 20mm holesaw through the tunnel and installed a grommet. Otherwise the wiring was too short. The sensor needs to be down near the back of the box and mounted as close to vertically as possible.
I Fed the harness up through the Shifter hole around the boot/boot holder. Just had to bend the steel boot holder a tiny bit so it didnt squash the harness. No issues at all
The shifter is only a rod into the gearbox, so theres no linkages etc around there, if you run it smart then theres no issues.
i just close the wire on the door. run them for many years like this... works fine. i do this because back in the day i only had one wideband sensor and i would need to remove it from my own car and use it on other cars that i was tuning.
never once had an issue.
Over at a mate of mine who is a retired panel beater/ spray painter, he suggested I look on the firewall for pre-existing hole that has been blanked off. As soon as he said it a light switched on upstairs and I immediately thought of the spot where the clutch goes through, will report back when I'm finished. :)
This was exactly what I tried after sussed out where the shifter goes through the transmission tunnel. I managed to get the coat hanger wire through the first rubber grommet, but it seemed to snag on another seal or piece of foam behind the firewall, it was getting late so I gave up and came in hear to post.
I positioned the sensor about a meter back from the turbo and 200mm from the cat. Tech Edge suggests the sensor is positioned between 15 degrees from vertical and 10 degrees from horizontal...
http://wbo2.com/lsu/lsuinstal.pdf
Edited by Missileman
If you take the shifter out and the boots off its easy to run up into the cab that way, then just put it all back in taking care not to crush the cable
But Where you have run it is fine, Shouldn't have an issue, just a bit longer distance for it to travel.
Saw that, but it looked too small, the small plug end on the tech edge cable is about 18mm Ø
Run the actual sensor through the hole from the inside of the car, surely the sensor will fit through. MIne does.
If you want to use the same grommet just put a clean cut through the side of it fro the wires and when it goes back on the car it will close up nice.
Edited by HR32GTS 4DOOR
You know he has already run the wiring for the sensor right?
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
