Trying to install a wide band into my auto 32 gtst and have run out of ideas on where to run the cabling form the sensor to the drive unit which is inside the cabin. I don't really want to drill holes in the floor or firewall. There is a rubber boot underneath the shifter for the linkage to the transmission, but this location doesn't appear to be suitable as it could foul the linkage. The other option is from the engine bay through the same route as the engine harness to the computer, there seems to be another rubber boot/ seal there which is proving difficult to guide the cabling through.
Interested to hear how others have routed their cabling into the cabin?
Cheers Mike.
https://www.sau.com.au/forums/topic/428940-wide-band-installation-help/
Pass it with the engine wiring. I use a coat hanger with the end bent back and wrapped in a little insulation tape (so it doesn't tear anything up too much) as a guide rod to poke through, then tape the wire(s) I need to drag through into the cabin onto the hanger and drag it in. I have used method that to pass through wiring for and air-fuel meter, a pyrometer, for the IC water spray, and so on.
  • Like 1
I ran a 20mm holesaw through the tunnel and installed a grommet. Otherwise the wiring was too short. The sensor needs to be down near the back of the box and mounted as close to vertically as possible.
I Fed the harness up through the Shifter hole around the boot/boot holder. Just had to bend the steel boot holder a tiny bit so it didnt squash the harness. No issues at all
The shifter is only a rod into the gearbox, so theres no linkages etc around there, if you run it smart then theres no issues.
i just close the wire on the door. run them for many years like this... works fine. i do this because back in the day i only had one wideband sensor and i would need to remove it from my own car and use it on other cars that i was tuning.
never once had an issue.
Over at a mate of mine who is a retired panel beater/ spray painter, he suggested I look on the firewall for pre-existing hole that has been blanked off. As soon as he said it a light switched on upstairs and I immediately thought of the spot where the clutch goes through, will report back when I'm finished. :)
This was exactly what I tried after sussed out where the shifter goes through the transmission tunnel. I managed to get the coat hanger wire through the first rubber grommet, but it seemed to snag on another seal or piece of foam behind the firewall, it was getting late so I gave up and came in hear to post.
I positioned the sensor about a meter back from the turbo and 200mm from the cat. Tech Edge suggests the sensor is positioned between 15 degrees from vertical and 10 degrees from horizontal...
http://wbo2.com/lsu/lsuinstal.pdf
Edited by Missileman
If you take the shifter out and the boots off its easy to run up into the cab that way, then just put it all back in taking care not to crush the cable
But Where you have run it is fine, Shouldn't have an issue, just a bit longer distance for it to travel.
Saw that, but it looked too small, the small plug end on the tech edge cable is about 18mm Ø
Run the actual sensor through the hole from the inside of the car, surely the sensor will fit through. MIne does.
If you want to use the same grommet just put a clean cut through the side of it fro the wires and when it goes back on the car it will close up nice.
Edited by HR32GTS 4DOOR
You know he has already run the wiring for the sensor right?
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
