Hey all :)
I have a problem with my skyline. Only occasionally I will start it and begin to drive.. then when I'm accelerating it seems to lose power and slightly "bunny hop" the bunny hops are not aggressive. it just doesn't seem to be able to get to higher revs. It does happen when it's cold but by the time it's warmed up it still has the problem.as I said it only does it every now and again. Does anyone have any idea what could be wrong?
https://www.sau.com.au/forums/topic/428944-intermittent-problem-with-r32-gtst/
No mods except for a coke can in the blow off valve (bought like that) :P
Don't know the service history from previous owner. Has had a complete full service. Was happening before I recently got it serviced.. mechanic changed the fuel filter and spark plugs (thinking they were the cause) but problem still persists
It happens at any revs. It happens whenever I accelerate
  • 1 year later...
Found this thread and am bumping it because I have a similar problem. I'll describe it in more detail though.
This happens occasionally, and only early in any drive if it does. Not like right out of my garage but 1 or 2 minutes in. I will probably happen at a frequency of about once every 3 times i drive the car.
Once it happens it will happen until i let it sit out of boost for a while and it will be ok. I even did 5 runs at autocross after this, problem did not crop up.
How violent it is depends on how much throttle i'm using. If I hold it down as i'm trying to accelerate and not let it if it reminds me as if someone who is just learning to driving a manual is driving the car. Off-boost it doesn't do this. It only does it at RPMs in which the turbo is building or holding pressure.
Same recommendations? I don't have another AFM to try otherwise I would but I could install my powerfc and put in a Z32 AFM.
I had an r32 gtst back in 2004 which would do that, the car would lurch back and forth violently under acceleration. Turned out to be a really dirty fuel filter, wasn't allowing sufficient fuel to the rail so the car was suffering fuel starvation. Upon reflection I'm surprised I didn't destroy the engine, must have been running ultra lean during those periods.
Did it do this all the time or only occasionally like it's doing for me?
I would think if it were a fuel filter it wouldn't just stop and be fine for hours.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
