Hello.
Ive found a nice m35 3.5lt rwd
My questions are
What have u guys paid for these b4?
Chain tensioner- how many ks until it needs looking at?
How is the timing adjusted on these? Automatic or manually?
Where can i get a rear boot matt from?
Common issues...
Do these suffer the rear end issues the earlier m35s had?
Anything i need to specifically look at?
I know electrics can be a prick on these,
How common, and what sorts of failures have you come across?
Rear tyre ware bad? And is fuel really 11.5 km/100? (Of course there are many factors but as a general guide?)
If/when i get it, ill budget for this,
Transport (syd to melb -who have we all used)
Travel to and from on a plane
Spark plugs
Engine oil and filter
O2 sensor (what one do i use? 350z?)
Brake fluid - check brakes
Power steer
Flush coolant
Rwc, rego, stamp duty
Insurance
Epic alarm
Cant think of much eles to ask atm. Any info is great!
In terms of mods, i dont need power, torque,looks.
I want comfort and fuel economy.
Is there a nice set of coilovers that are quite comfy?
And is there alot to gain with exhaust mods. (Dont want it louder than it is)
Thanx all
https://www.sau.com.au/forums/topic/428945-vq35de-and-m35-axis-help/
Please see answers in caps. Sorry, not intending to interwebz shout, just easier for you too see and read ;)
Hello.
My questions are
What have u guys paid for these b4? WHATEVER ITS WORTH.
Chain tensioner- how many ks until it needs looking at? 250,000+ I'M GUESSING. DEPENDS ON SERVICING
How is the timing adjusted on these? Automatic or manually? AUTOMATICALLY
Where can i get a rear boot matt from? YAJ/STREETER/IM
Common issues...
Do these suffer the rear end issues the earlier m35s had? DEFINE ISSUE PLS
Anything i need to specifically look at? SAME AS ANY OTHER USED CAR
How common, and what sorts of failures have you come across? NOT PERSONALLY, BUT ENGINE CAM/CRANK SENSORS, INTERIOR SCREEN
Rear tyre ware bad? And is fuel really 11.5 km/100? (Of course there are many factors but as a general guide?) NO IF ALIGNED CORRECTLY, AND YES, I'D BE STOKED WITH 11.5. MINE DOES SHORT TRIPS AND IS ABOUT 14/100. ON THE FREEWAY A BIT BELOW 10
Spark plugs
O2 sensor (what one do i use? 350z?) GOING TO REPLACE ALL 4....? MIGHT GET EXPENSIVE....
Power steer
Flush coolant
Insurance
Epic alarm
Is there a nice set of coilovers that are quite comfy? READ WHAT YOU WROTE IN THE PREVIOUS 2 LINES - WHY WOULD YOU WANT COILOVERS...?
And is there alot to gain with exhaust mods. (Dont want it louder than it is) NO
Thanx all
In terms of coils, im thinking of shagged out stockies not being any good, due to age, kms, and conditions
M35 issues are rear cradle mainly. Turbo also but this is N/A
The screen is it a pixle issue, or just dies? Easy to come by?
And is the cam sensor a prick to swap or is it not too hard?
Bc coil overs is what most run when they get them. They aren't harsh, but if you can get your hands on bilstein shocks, you'll be pleased. There are a lot of options
Haven't heard of a cracked pm35. Some theory is that hicas increases the chance of crack, but overloading and rough roads stiff springs is a bad combo. It's a simple fix. Weld it if cracked.
The motor that makes the screen go up and down can be temperamental. Haven't heard of replacement, but wouldn't be simple
Easy enough for a confident home mechanic. Back of either head, and in the bell housing.
I need a bloody matt for the back.
The bulldogs claws dont like leather
There are few on importmonster about 60-80 plus postage. If not got to clark rubber and make one out of thin rubber. I think scotty nm35 got his made up if I remeber about a year ago if I remember correctly.
Keep us posted with how you go Chef.
I'm interested too, the simplicity of PNM35's really appeals to me as I don't drive in snow/icy conditions. Non turbo is a big win also given how "one of a kind" the NM35 turbos are.
Without driving one it's hard to know how they are power wise - reading the specs a bit more than the NM35's from factory but obviously a lot easier to pull more out of a NM35 without more major modifications (bolt ons, mainly).
My other concern is fuel economy. I used to get excellent economy out of my NM35 - just over 10L/100km around town assuming I was wearing my sensible pants and as low as 8L-9L/100km on the highway without air cond.
I think if I bought a PNM35 I'd be organising a remap for it so I'd be hoping that I would be able to get those sort of economy figures out of one.
:/ remap for fuel economy? Isn't it expensive just to do a remap for fuel economy? and you might not get what you'd be hoping for, wouldn't it be cheaper to get it gas converted?
I'm a 4th year apprentice, I also have another job, completely independent. I manage 250km to 270km for half a tank on average and the car is my daily, it's hell unpractical as a daily, but I love the car to bits reason being it offers soo much and for me they outweigh the cost of running the thing and I'm not just talking fuel economy. If I wanted a car that was big, fuel economic and would save more money compared to a PNM35 I'd be looking at probably a diesel wagon or an SV6 or something...
You'd probably save more by spending 100$ a week at Coles or Woolies and use the fuel discount rather than a remap or get another NM35 as the savings of fuel you get over a year you can budget for tubz? Then next year with the same savings you can get a couple AFMs as spares.
Not trying to talk you out of PNM35's but one thing they ain't is economic :P.
But on to the mechanical issues, the only issue I've had was a split CV boot, the rear diff was weeping but that was just a blocked breather I was told, and I've replaced the radiator. The car has almost done 144k kms and I've probably put about 10k kms on myself.
Edited by M35woah
Engines have become a lot more efficient, these things run wideband o2 correction... But it's still 3.5L in a 2 ton car...
Liquid gas conversion would be the go like Matt said.
SV6 isn't going to be any better on fuel, nor is the NM35. Even the missus A4 1.8t only gets around 9L/hundred on the hwy.
Just going on what Jasevr4 has stated what he got previously, and the SV6 is just going on redbook figures.
The figures that Jase stated put the PNM35 to shame, there is no way I can do 10L/100km around town unless freeway town.
