^What he said
Also, high flow cats make a noticeable difference for both power and economy.
Any way you can remove/minimise restrictions will net you a slight increase in power and economy.
Pm35 power is good enough for normal commuting but does not have the torque that the nm35 has.
Also, the 3.5 doesn't really do much below 3000rpm. It is better than the VQ25det down there, but is much more enjoyable between 3500-6000.
As an ex-nm35 owner and current pnm35 owner, there is no chance I would go back... even though I do miss the torque from the turbo.
you will never re-map it for more fuel economy. It runs wideband o2 connection as scotty said. Unless you want the tuner to lean tune it and loose torque to gain economy, it just wont work. Removing the fuel out the top end will give economy, because it runs <10.5:1 AFR in the top end, but if your that concerned about econ, you wont be flogging it.
anyway, its just not economical. So youll need to get over that if you want one, or buy a diesel.
ECU dictates the target AFR, not whether the car has wideband o2 sensors or not.
Remap for a leaner AFR would mean better economy. Nobody said that the tune has to target 14.7:1, especially if you manage a way to get a more complete and efficient combustion process...
As Alex mentioned, leaning out the mixture drops the energy available to combust and usually means you need to put your foot down more, just to get the torque required to cruise. I must admit I haven't played around with petrol mixtures a lot, as leaning out 98 is a bad idea generally, but running a huge range of ethanol tunes from 10:1 through to over 20:1 on cruise I now realise near stoich is where it's at. Leaning it out to 15's is going to barely make a difference to the wallet unfortunately. Foot control of the pedal has more chance of fuel savings.
Seriously, they are never going to be lean running cars, they are simply too heavy to compete with modern buzz boxes with their skinny tyres and sub 1 ton weight. Thinking a quick retune will gain noticeable savings... Perhaps if you plan to do massive k's to cover the tune costs. Limiting the throttle to 20% would be a better idea. :P
[minor threadjack]
front wise, anything from 350z/V35 to the end of the Y pipe, rear of that, anything from a V35/G35 sedan
Does this hold true for PNM35s as well or does the AWD get in the way? I've been trying to find something for mine and while I've found the Zee's ones on YAJ they'd cost over $2K landed here in NZ and I'm pretty sure I could get a reasonable custom one built for that price.
[/minor threadjack]
Edited by Hertz Donut
[minor threadjack]
[/minor threadjack]
The Y pipe 350z v PNM35 is very different, to get around the transfer case. Thats one difference. The other potential difference is the front shaft with HFCs or test pipes. I just don't know if they will fit or not. Some have massive seperate chambers etc, but the normal single HFC ones should fit ok.
Carbon canister is still there, it just sits horizontally and without the bracket.
V36 exhaust has massive rear mufflers and yes, the driver side one has to be "persuaded" to clear the spare wheel well lol.
Also, Scott had to weld up two additional exhaust mounts to hang the driver side on.
No problem with HFC's from the US. My PNM35 has G35 Berk cats which bolt straight up to the standard exhaust... they also bolt up to my V36 exhaust.
NM35 cat-back exhausts will also bolt up to a series 2 Y-pipe, regardless of whether it is 2WD or AWD.
As Alex said, the only thing that won't fit is the 350z/G35/V35 2WD y-pipe, so if you are looking at a US exhaust make sure it will fit on a 2003-2004 G35x.
Also, forget any coupe exhaust due to the spare wheel well.
If you are looking at headers, be warned that some of the 350z headers will foul on a PNM35 bodywork. You can fit them, but some will be sitting on the bodywork which is not so good considering how much the engine can move...
Zees exhausts cost heaps but seem to be very good quality from everything I have read (sound good too). Probably cheaper to get someone to fabricate up some exhaust mounts to fit a V36 exhaust and purchase a V36 (or G37x compatible) exhaust if you want dual mufflers though ;)
  • 3 years later...
Reviving an old thread here. (trying to find info on using different model cat back exhausts)
I've got a pm35 stagea, wondering if other models like M35 or NM35 aftermarket cat backs will bolt up?
For example:
https://www.rhdjapan.com/fujitsubo-legalis-r-exhaust-muffler-nm35.html
Cheers
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
