I too blocked off the top vac line from the solenoid to the Tee-piece. A lot of people says that this has no effect on performance but I think this should be looked at as the solenoid is obviously hooked up to the ecu, and by eliminating this device, would it effect the way the ecu makes it's calculations? Ive noticed my '97 serII is drinking a bit more after I blocked off this line.
The car will obviously still run, but what I'm really concerned with is if the engine is gonna run leaner/richer......i.e does this boost solenoid effect the way the ecu deliver the messages to the fuel system.....I doubt this solenoid is an independent device and it could be associated with the rest of the system in some way, would it alter the other parameters by turning it off?
Chrisgero, this happened to me too, but what actually happened was the vac line from the boost controller to the actulator wasnt tightened properly and popped off when I was givin it, the bitch peaked somewhere around 20 - 25 psi..... mine too made a huge-ass 'POP' as if the turbo had exploded, I freaked right out.
Blocking off the hose to the solenoid will just give you no boost increase as it stops the bleed off of pressure. Bypassing the solenoid is asking for problems as the solenoid itself is also a restricter, bypassing it will just allow uncontrolable boost. The is no feedback from the solenoid to the ECU as it is an ECU output, simply switched to ground by the ECU to turn the solenoid on, thereby letting the bleedoff occur. The only reason fuel consumption would increase by turning the solenoid on all the time, or sooner, is because boost is increasing earlier, therefore more fuel is needed.
  • 4 weeks later...
whats the best way to adjust a bleed valve anyway? ive just bought my car recently and it has one on it but i haven touched it. its supposedly set to 7psi but ive never really seen it go past 5psi. im thinking that the bleed valve is closed completely and seeing that the solenoid would have been disconected im just on low boost all the time.
  • 1 month later...
did this mod jus then haha wat a good find! scared to do it at first but yeah worked out all good i didnt even use that lead wire.. i jus cut the black, stripped it and wrapped it around the bolt haha same thing... gg paulr33 wid this mod
haha no problems. glad your enjoying it. someone else had done it long before ive have but they never posted how to do it so i cant take the credit for all of it, i just tried it once after looking at the rb25 diagram and thinking how it could work and then tried it and it worked. enjoy
by doing this mod , will it effect the running of my power fc (which i havent installed yet)?
mate ive got a power fc and i done the boost thing and the only thing i see going wrong is my petrol ;) hahaha but other then that love it..
  • 2 months later...
Hey all i just signed up cause i got a 94 r 33gtst
Just askin but when i got the car it wont run over 5 psi i tried a little pipework and ran it wayyyy past 7 pound cause the overboost mechanism kicked in lol. (put it back soon after)
i wanna do the wire job to test it but does neone have an idea on what could be wrong with my car?????
  • 4 weeks later...
lol i thought i broke my car till just now lol!!!
i've chopped my wiring up now to =(
ahhh well least now it might work ???
dont know if this will help ne1 i got some of those lil screw down terminals from jaycar i think they cost a $1.50 made doin this a breeze and its also reversible if i want =)
HI buddy,
Sounds like a quick and easy mod. Im just wondering it you can do it to an auto??? i have r34gtt tiptronic. i think they run slightly higher than standard boost when stock?? or is it just always on full boost no step up in boost levels after certain rpms like the step which this mod gets rid of?? I am not too sure
i would really like to know though coz if its the same as a manual i will do the diy mod asap.
any help would be appreciated
i got no idea bout auto's/34's etc.. but when your driving around do you get extra boost at 4500rpm ?
If you do, then you should be right to do the mod. Either way though, it only takes a second or 2 to fix back up if it doesnt work.
Could someone please send me a link for the type of switch I would need to use for this setup. I want to put one in so I can flick it one way for 5/8psi other way for 8psi..
I've bought one from dick smith that has 3 prongs on it and I was guessing it should work however I can't even get it to work with 2 little LED's and a battery.. so either I suck - or I've bought the wrong switch - which I think is the case (hopefully)
Never mind - i've sorted it myself - i've purchased the following:
http://dseau.resultspage.com/search.php?p=...34&site=&w=7701
for anyone that doesn't know anything about electronics you need a SPDT switch which is the following:
SP = Single Polarity - DT = Dual Throw - which pretty much means that if you flick it one way 1 thing turns on - flick it the other way the other thing turns on..
good luck!
installing a switch as i'm doing will stop this issue..
also - it only runs 8psi when it's spooling.. so really.. it's up to you and how hard you want to drive it...
shouldn't be to much of an issue.. most people drive with 10psi aftermarket..
thing you should be more worried about is the boost solenoid - having 100% grnd all the time..
put a switch in and only use it when you want to..
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
