nah stock boost is 5 - 7psi..
when you go past 4500rpm the boost solenoid thing opens and gives you the extra 2 psi.. so you get 7 in total..
What do you mean 1+ ?
7 on the stock boost gauge means 14psi if thats what your talking bout ?
r34 stock boost gauges go from 0 to -700 and up to +1 on the gauge, anyway i guess its a safe mod to do that wont damage the turbo.
Whats +1kg/cm in psi?
Edited by RyanN
1kgcm2 is 1bar which is 14psi. this will fry your turbo. max you should be running should be 11/12 psi as this is border line. the heat from runing that much boost will fry the exhaust wheel
ok, wasn't sure if this mod was damaging the turbo or not, as i dont exactly want to blow the thing yet :P
Before the mod the gauge would go just below the halfway mark and after, just above it; that would be around the 7-8psi mark?
Its the pressure that shatters the turbine wheel right not the heat?
Edited by RyanN
hey paul.......i thought .8 bar was around 9-10psi.....is it in fact 11-12 psi? i remember from the discussion over on skylineowners.com that all the guys said not to run more than .8 bar b/c that's the max you can safely run the stock turbo at
Late,
Daniel
sorry my grammar kinda made my statement a bit strange. here's what i really meant
max you should be running should be 11/12 psi as this is border line. the heat from runing that much boost will fry the exhaust wheel.
yes 0.80 is approx 12psi. i run 0.85 daily and its on border line of frying it and it doesnt make any more power past this level either, but stacks more heat, which is the killer
9psi is around 0.65 bar
Hey guys, im another proud R33 GTSt (series II) owner! My R33 is completly stock besides the K&N pannel filter... Can some please either email me or post up some pics showing the factory boost solenoid?
Thanks
Thanks
Heres a pic of one:
http://bur.st/~rinmak/r33/IM001060.JPG
Its the silver thing with one pipe coming off of it and an empty nipple beneath that.
Yours probably wont have an empty nipple though :D
each psi is a noticable gain however you should make sure you have a good exhaust and fmic before running that much pressure
i'm hoping to be able to get my downpipe and de-cat pipe done this thursday (already have an 80mm cat-back on the car)
and my friend is going to give me this MASSIVE Calsonic SMIC (over 6 inch thick core)......I think that core will be good up to 300whp
Late,
Daniel
Hey guys,, just did this mod and am confused as to what my stock boost gauge should read,, The solenoid is operating (I put in a switch,, but the boost gauge only gos to .35,,is that right? I thought I should get more than that,, car is completely stock except for 3 inch high flow cat and nismo exhaust,, Is there something wrong or is that all I can expect without spending some coin?
cheers,
John
John, the boost gauge that is in your OEM gauge cluster should be reading half way above the half way mark on the gauge which works out to .7 bar or about 9psi of boost.......if its still only reading half way below the half way mark (when below 4500RPMs) then you're running .5 bar or about 7psi of boost
hope that makes some sense :D
Late,
Daniel
hope that makes some sense :)
Late,
Daniel
Thanks Daniel,, I bypassed the controller and it spiked (just after the computer confused itself and then re-mapped of course) so I put the controller back into the loop,, it still only goes to right on half way, so I'm guessing that either the gauge is dodgey or the actuator is not quite right,, might just make up a bleed valve and have a play,,
cheers
John
no problem John :D if you were running high boost (.7 bar) you would DEFINITELY notice the difference in the lower RPMs when compared to .5 bar at the lower RPMs :)
what i did was peel back some of the insulation on the black ground wire, spread the core apart in the middle and looped a my additional ground wire through there, I then soldered the wires together, taped them up nice and tight, and proceeded to wrap the other end of my ground wire around the bolt that hold the power steering reservoir bracket onto the shock tower
i hope this helps.......if it make sense :)
if not i can try and take a picture of my solenoid and wiring as it stands now later on today or tomorrow
Late,
Daniel
Hey Guys, you think by running a direct ground signal to the earthwire of the boost solenoid while its still connected to the ECU will damage the ECU??? cause thats what i thought about doing as well as adding a switch but was worried about damaging my ECU.
Regards,
Sarkis
Alright guys, i finally had the time to do this little mod on my R33 S2 and it works! i noticed my rev range being more smooth and more comfortable without that nudge you feel at 4500rpm... you can see full boost comming on as low as 2500rpm (little over the halfway mark on the factory guage) acceleration wise i noticed a little increase but nothing too drastic, perhaps its cause i still got a stock exhaust???
i managed to find a way to wire up this mod up without any cutting or soldering! i used the airbox bolt for my earth and fed the wire into the harness as shown in the pics... this way you can remove the mod and everything is still original!
Nice find paul!
Regards,
Sarkis
no problem John :)  if you were running high boost (.7 bar) you would DEFINITELY notice the difference in the lower RPMs when compared to .5 bar at the lower RPMs :)
Late,
Daniel
Thanks Daniel,, I did put a switch in and wired it to the power steering mount bolt, then I taped it all to the harness so that you can only just see the switch hiding behind the air box,,
I will endevour to play around with some sort of bleed valve arrangement and wire in a relay so that it can be switched from factory boost controlled,,to factory maximum boost and also to have a bleed valve arrangement as well (three way switch),,,I will post the results when I'm done,,,
cheers
John
I just dyno'd my car with this mod, except when I put this mod on I put a on/off switch for it, the difference between ECU relating boost at low revs, and earthing the wire seamed to be nothing at all!
Saying that I swear it made a difference when I did this before I dyno'd it!
I'm at a small loss now, if you put a couple of washers under the wastegate actuator mount points it increases boost BTW, not the best tho, my fuiel cut defended cut in and shut the car down for %60 of the rev range, when it was boosting hard tho, it was f**kING HARD
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
