hey fellas i'm very interested in doing this mod on my car i just dont know enough about
it. :( is there any picture guides on how 2 do it?
i had my mechanic do an aftermarket boost controller on it but i think its stuffed and its spiking and i'm overfueling cause of it.
help please
help please
get the mechanic to put it back to stock boost control solenoid/setup then just ground the black wire between the solenoid and plug, seriously its that simple (or tell im to do that) ie cut it and attach it to car body - ground
or even grab one of those turbotec boost controllers in forced induction section $22 thing if u want a few more psi
my r33 just used to sit on 5 psi never went any higher so dont know where the 7psi side of things went but did the mod today took all of about 10 mins and now it goes to 8 psi comes on quicker pulls harder than b4 im rapt mid life crisis
Ok this may seem like a stupid statement,(As i dont actually own a skyline yet) but i always thought that if you upgraded ur exhaust, say 3" turbo back, ur boost automatically goes up. In saying this would this mod still work? Please detail ur answer as im new to the turbo/skyline scene....LoL
Cheers
this mod will still work. boost is a resistance to air, take out the resistance aka bigger exhaust and boost will go up a little as there is less resistisance, so it can flow more but the mod will still apply
wouldnt the wastegate actuator stop it from going over a set psi regardless of the size of the exhaust?
Thats another thing i was thinking but didnt wanna say...
A larger exhaust (more flow) allows the turbo to spin up easier, and as such faster, here in NZ we rip the insides of our cat convertors out also to create less back pressure...
Yes Yes Yes....I realise this BUT will the actuator/ecu/solenoid etc stop it from gaining the 'automatic' boost you get as a result of putting a bigger exhaust????
I realise the effects of a bigger exhaust on a motor/turbo but will it be electronically restricted?????
well, when i first had the rb25det in my R31, i had the stock 1inch exhuast, and it would only make 5psi of boost, when i put on a 3inch turbo back it did the 5psi, then 7psi after 4000rpm but that is all, the actuator will stop anymore boost from being made. I also install one of them $30 boost controllers, its all pretty damn fine now.
I did this mod last night, and bang me dead its awsome!
can anyone tell me what having this loop does(drawn in red)....cuz in my car the solenoid has a loop...the top one doesnt go where its supposed to go....i need an explanation on what this does....esp cuz am a newbie to skylines...he he ;)
wouldnt that be done just to plug up the solenoid..?
can anyone tell me what having this loop does(drawn in red)....cuz in my car the solenoid has a loop...the top one doesnt go where its supposed to go....i need an explanation on what this does....esp cuz am a newbie to skylines...he he :D
the bottom one runs to your wastegate actuator, without this you car will probably boost until the fuel defender cuts in
the top one should run to your inlet piping after the air filter, i blocked mine off (top one) but have since unblocked it and it makes no difference
Edited by Keeper
My setup is abit different from everyone else's. Is it still ok to do this mod since the 2nd solenoid nipple is being used?
And if so, which wire goes to ground, white or black?
This mod looks great!
Just thought I'd ask if anyone had successfully done this on an R34?
I would guess that it would be almost identical procedure?
I have noticed that on the R34 boost is limited in 1st and 2nd gear, getting the full dose in 3rd through 5th. Would this mod "rectify" this boost cut in lower gears? Thanks guys!
  • 4 weeks later...
Never mind - i've sorted it myself - i've purchased the following:
http://dseau.resultspage.com/search.php?p=...34&site=&w=7701
for anyone that doesn't know anything about electronics you need a SPDT switch which is the following:
SP = Single Polarity - DT = Dual Throw - which pretty much means that if you flick it one way 1 thing turns on - flick it the other way the other thing turns on..
good luck!
Just purchased one of these things and about to give this a shot.
On the back it's got three pins. 1. 2. 3.
is it
1. Wire leading to ECU
2. Wire leading to actuator
3. Wire leading to ground
Have I got it wrong?
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
