There isn't much difference to fuel economy. Remeber, your accelerator pedal can also control the amount of boost. So unless you fang it 24\7, thre wont be much difference. If you do fang it everywhere...the difference is about 30KM's per tank
Yeah thats about the result I got. not much diff to fuel economy. Noticeable performance improvement in lower rev range tho!
may i just say that the stock boost is so boring now. i hooked my solenoid back up last night for something to do. after running 11psi, 7psi feels really slow.
Edited by mad082
hey mad082 have you got uprated turbo or anything else to be running 11psi? (just confirm for me ..that is about 1.1bar of boost right?) how are you upping the boost ..with a boost controller or anything else?
after a while of driving with the boost solenoid earthed permanently (as per tutorial) I generally see about 0.65 to 0.75bar of boost. I've heard stock tubbys are good for a safe 0.9bar so not too worried. Its a shedload quicker off the mark too esp. if I find a good bite point.
..going to collect me car today - had a twin plate OSgiken and lightened flywheel fitted too hurrah! should be funny when I get my hybrid turbo in :wave:
1bar is about 14psi mate
sorry this is a little of tpic but i'm having issues with my apexi avcr boost controller, a dumb arse workshop cut my vacume lines comming out of the soliniod can't seam to get it right, i need to know what the 2 vacume hose on the pic conect 2, i know one is the actuator, can someone show a pic of the second or explain in detail cheer
thanks 4 the pic anthonymcgrath
i'm using a turbotech boost controller. 11psi is only about 0.75bar (14.5psi = 1 bar). i find it interseting that people get such high readings off the stock solenoid. but then i don't have mine grounded. i have full turbo back exhaust, fmic, pod, and when i went out the other night on it it wasn't going above 8psi. but then i didn't check on my turbo timer to see what it spiked to.
the other vacuum hose goes to the intake. as to why they cut it i have no idea. when i hooked up my boost controller i just kinked the old hose that went to the actuator and let the other hose hooked up and it makes no difference.
my car went to 8psi with a cat back, and 9psi with full 3". sits on 9" and holds all the way (with stock boost stuff - havent put my turbotech on yet)
it might spike to 10ish for a second on a cold night if u plant the foot, but holds at 9 straight after
i wasn't paying much attention to the gauge. i just pulled out of the driveway, dropped it into second gear and loaded it up to see what it went to. i was only doing about 3500rpm when i looked at it, so it hadn't even gone into high boost mode, but back when i first got the car and it was completely stock the gauge would go to 7 all the time, but you could feel the it kick in at 4500rpm.
well actually when i first got the car the stock gauge wasn't working, due to a vacuum hose being unhooked in the engine bay. so the first servo i got to i went hunting in the engine bay and found the hose straight away and hooked it up. then when i got home i hooked up a boost gauge and discovered that it was only going to 5psi. so a day or 2 later i hooked a power wire up to the solendoid to make sure it was switching on when it got power. started to drive to work and it was still only going to 5psi on the gauge. stopped at autobarn on the way to work and when i took off up the road it went to 5psi in first then changed into second it went to 7psi straight away. so it buggers me what happened.
EDIT: WARNING: DO NOT use my method - below.
I tested it and my boost gauge showed 14psi, and climbing.
My foot was only half way down, and revs had only reached about 4500.
Wouldve kept climbing if i didnt back off.
Hope i didnt F*CK anything. Any thoughts on that ?
strip a wire long enough to feed through the male clip and around into the contact point.
you can feed the wire in thru the back of the clip, exiting as seen in the pics.
clip it back together, ground the new wire , or run it thru a switch first, and the mod is done.
totally reversable, no cutting, and not very detectable if you use a subtle colour like black.
see pics coz my explanation sucks.
Edited by Munkyb0y
kinda cool I like it! I just ran with snipping the wire - its easily replaceable in the end :happy: the infinite boost thing is interesting tho - what on earth happened there then hehe!
  • 3 weeks later...
cheers mate thats exactly what i was looking for i didnt want to chop the exsisting wire :mad:
im sort of new to this "boosting" thing...just wanna ask afew questions
if i get a "turbosmart bleed valve" and set it to 10psi and also use the "high boost mode" will i be able to make 10psi before 4500rpm...at lower revs like 2500rpm? will it work? and is it safe for daily driving?
r33 gtst......pod, full zorst, FMIC
thanks
If you use a bleed valve then that negates the standard actuator. If you set the bleed valve at 10 then you will have 10 all the way through the rev range. If the bleed valve is already installed than the standard actuator should be disconnected.
10 Psi should be safe for daily driving as long as you have a FMIC. Best to have a dyno run after too ensure fuel pump is up for it (They should be but sometimes they fail). CRD and UAS doing them for around $80.00.
Basically the mod listed here is for peope who want to use the standard actuator to get full boost (7-8Psi) right throughout the rev range.
Just wondering, how does having a fmic make running 10psi "safer"?
Safer..probabaly. Your standard SMIC will not handle 10 PSi consistently. It will be come heat soaked which leads to hot air going into the turbo.
Then again..if you have mature throttle control and only wanna hit 10Psi once a day or so then that will be fine. Just because it's set at 10Psi doesnt meen you have to hit 10 everytome you accelerate
thanks Kennedy for ur help
just one more question....
will i get the "Rich n Retard" problem at 10psi?? on S1 r33 GTST
dont know too much about it...wat symptoms will i notcie if i get it...eg flat spots? or will it be fine??
thanks
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
    • Yeah, all good ...got your postal addy as well ; I'll box the stuff in the next couple of weeks, you can paypal me later..
    • Hello! I had a mid life crisis on a budget and coincided with the R34s being legal in the USA. And now I am here, with it having old car problems and me slowly hoarding parts to start building it to what I envision. Essentially I made a mistake, that lead me to join this forum filled with legends.
