Ok so I did this mod 3 days ago, I have a r34 gtt sedan, doesn't come with a boost gauge, the
Mod worked great then yesterday it felt like it was back to normal, anyway I read some1 posted bout joining the 2 connecting hoses on the solenoids together, so I've done that and my car goes like a rocket,my car has been converted to manual and also had the turbo replaced with another 34 turbo but was told it was reconditioned and had a steel wheel, my car doesn't back fire at all and it feels like its running more then 7psi... I will get a boost gauge ASAP but have I done something that I'm going to regret or not cos I'm loving this power....
I also did try disconnecting the bottom hose on the solenoid to see what it was like and I hit some kind of cut at around 4200rpm so I put it back on... But now I've connected these hoses it feels amazing and has no sign of cutting out or leaning out, it's real smooth, feels like its hitting full boost at around 3k, is it possible that I have a 32 actuator in my turbo? Also I still have the black wire earthed, only other mods is a k and n pod, still stock exhaust...
Yep.
1) Get a boost gauge ASAP.
2) If you disconnected the bottom hose and didn't plug it, then you probably had infinite boost (til stuff go boom) cause the actuator would have no pressue to it and wastegate wouldn't have opened.
3) You could have a 32 actuator. (pics?)
Scroll up ^^^ to post #608 the first pic shows an actuator. (the brassy coloured thingo with the hose going to it)
Looks to be an R33 one. R32 the hose comes straight out the side. (down I think)
Edited by Not a Pulsar
Between turbs and strut tower. Easy to see if your head is the size of a tennis ball. :rolleyes:
Look closely and you will see it.
  • 1 month later...
Finally got around to doing this today. Car feels to pull a but harder when coming out of a corner in second. Haven't had the chance to take it for a big hit yet.
If it's not done correctly it will only boost to ~5psi correct? On my stock 34 boost gauge she sits a little over halfway to +1 which would be around 0.8 bar is that right? Only mods are full 3.5in turbo back exhaust and FMIC so this would constitute slightly higher boost than normal right?
fun, cheap little mod
If it's not done correctly it could go to infinite boost or 5psi.
Personally, I would not trust the factory gauge - whilst the boost sensor reads accurately, it's impossible to get an accurate measure on the actual boost you're reading. If you are hitting 0.8 bar that's 11.6psi - which may be on the high-side.
With a 3" exhaust & FMIC - without this modification - I was hitting around 8-8.5psi through the mid-range. Even with a 3.5" exhaust, I wouldn't have thought you'd be hitting 11.6psi - but maybe it is. I ended up fitting a 10psi R32 actuator to get a steady 10psi (0.68 bar) - which is safe on the factory turbo. I quickly hit R&R when I let the factory boost solenoid connected as well so this was dropped.
Either way - yeah, maybe temporarily (or permanently) drop an aftermarket boost gauge on there, I'd be surprised you not hitting R&R if you are hitting 11.6 psi..
Nah definitely not getting infinite boost as it peaked just over that halfway mark on the gauge as I mentioned. Yeah I know the factory gauge is pretty dodge - I wouldn't mind a proper accurate gauge, I think it would be wise if I eventually get a nistune. Do you know if it's possible to just change out the factory boost gauge and leave the others (apart from looking a bit meh)?
I guess the question is - those who have done this mod and are still using the factory R34 boost gauge, where does ~5psi sit? Pretty sure I have done the mod correctly....it doesn't look like rocket science.
erm...whats R&R :blush:
Got it, thanks.
It feels fine but will get more of an idea of the changes when I take it on my usual circuit.
I know it has been asked already but is there any longevity problems with this mod? I'm sure there are people that have been running it for a number of years now..
Got it, thanks.
Runing this mod for 1 1/2 years, daily no problem.
Yep all good for me too, car seems to have a little more punch around the 3k rpm mark but no change higher in the rev range. Induction noise is almost bordering on annoying down low.
Would recommend this to everyone with stockish setups.
  • 1 month later...
Hi All,
I did this mod on my stock 96' S2R33 & now she wont rev past 2500rpm.
I freaked out (cause I just got the car), &put it back to original(re joined the wire),
But still only reving to 2500rpm...
Please help, I'm new to skylines..
What could be the problem??
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
