Why on earth would you want to run lower boost down low? That's heaps pointless.
hahaha sorry when i posted i was thinking if i did this mod then the solenoid would run 7psi down low instead of 5 but then the boost controller would run 12psi up high. I worded it all wrong. Im new to forced induction.
Make the auto transmission last longer is my guess.
Answer above :)
  • 2 months later...
what does high/low boost read on the stock guage?
as in what KG/CM2?
Stock reading as in x100mmHg (millimeter of mercury)
+7 on the gauge is about 13.5psi..
So 5psi would be about 1/3 of the gauge and 7 would be around half way?
Someone correct me if im wrong.
trying to work out what boost im running on the stage,
for some reason the prev owner installed an aftermarket guage which reads another random unit.
stock guage
aftermarket
so 0.6 is... 8.5psi?
does that sound right for high boost for a 25 neo?
Edited by GH05T
0.6 bar is 8.7psi, so yeah you have about8.5 as its a bit under 0.6.
and yes that sounds about ok. depending on variables/mods...
oh, and that aftermarket gauge is 'bar' which is pretty commonly used as well as psi.
Edited by Sklyn
  • 1 month later...
  • 1 month later...
ok fellas . read ALL this. am rebuilding an S1 R33 (don't know its history.? ) no boost actuator under bonnet ..? so bought one.. NOW I find out there is NO PLUG for this unit in the loom anywhere..??? SO...am thinking a "MBC" is the way to go..? ( I have a few sitting here ) but for the life of me cannot remember how to plug one in the system on a R33..? cannot seem to throw a pic up to show you NO PLUG..?
can a member give me a quick PIC please on where a mbc goes in these lines please..? and will ditch/remove the stock one being I can never get power to it :angry: ...!!!! all the best...nick .
OK. have "searched" this site and FOUND some answers.. :yes:
Edited by terryterry147
  • 1 month later...
Hi guys, I'm trying to do some detective work on what my cars previous owner got up to. I think he may have done this mod to my R34 GT-T, though it's kind of sloppy. In the attached photo, you can see the open wires.
Now, I have an aftermarket boost controller, meaning I should not have to worry about this variable boost. However, this is not my issue. I thought that I should cover up the open wires pictured, so i sprayed contact cleaner on them and wrapped them in electrical tape - first I taped the black wire, then i taped that tightly to the white wire.
However, I am now constantly blowing my tail light fuse (which includes dash lights and parkers). Could this possibly be related, and does the black wire need to be earthed?
Thanks!!
Cheers for the reply, I appreciate it
I would be looking at where the EBC is getting power from. ie in the dash / console area etc.
I've blown that fuse wiring things like gauges before.
Sorry mate, but what was the EBC?
I've checked the tail lights, they are OK, now i start the long process of elimination. Apparently cigarette lighters are often the main culprit.
Electronic Boost Controller.
Lighter is often used to power gauges etc...
Of course, when i did the stereo install I do remember that it was taking power (or at least ignition/illumination) from there - what should i be looking out for?
  • 6 months later...
  • 5 months later...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
