HOWTO: RB25DET High Boost mode with standard solenoid
paulr33
The other option for removing the 2 stage boost is to pull the two hoses off the solenoid and just use a small piece of pipe as a joiner. As long as you leave the original pipe with the restrictor in it in place you will get the "hi boost" pressure all the time. (about 7 or 8 PSI)
What you can also do is replace the small hose with the restrictor with a piece of vacuum hose and play with the size of the hole in the joiner pipe. I found that filling it up with "Lumiweld" (aluminium solder) and drilling it to 7/64" (2.78mm) I get a momentry spike to 12PSI which drops off to 10PSI and eventually decays to about 9PSI by redline.
The difference in the driving experience is fantastic.
Even just getting rid of the solenoid out of the system and getting standard hi-boost all the time makes the car much more fun to drive.
150% recommended.
I have recently purchased this Skyline and decided to follow these simple instructions. The Skyline had an adjustable boost control and either way I turned it to Positive or Negative it had the same boost Max 9lb.
Being new to the Skyline movement from the humble SS Commodore, I have been converted. However, not being a mechanic I placed all the hoses after removing the boost controller back to the standard solenoid and re-wired the white wire to the body of the car. I then tested the theory by taking the car for a spin around the block and it spiked to 20lb boost, it scared the S@#@ out of me because the Skyline backfired and I thought I blew the turbo, it was only for a split second then i backed off straight away. I got back home and found the hoses were in the wrong position.
Now the car is pushing 7 - 8lb and it is smooth. Could someone please tell me what the hell I did wrong. Have i damaged anything that will haunt me later. Im good with V8's but not with these TURBOS.
Chris , Sydney. :flamed: :throwup: :Bang:
  • 5 weeks later...
hi im new to this business and my skyline i recently perchased at this setup already installed but my r33 has a stock 34 cooler and a custom air intake and 3' exhaust. with this boost setup my car runs just under 10psi.
is this normal?
if so can i run a switch of the ground wire and would the off position run the stock boost setup?
thanks for your time anyone?
i think what would have happend when your car ran 20psi, is that the actuator wasnt connected and it just boosted infinatly.
ive set up a switch on my car, but found i loose around 50km per tank of fuel in economy if i run the 7psi constant thing so i switch it for having fun then switch it back off.
Guest RedLineGTR
Can’t you just disconnect the solenoid via the plug? I know it removes the two-stage boost but at what level does it keep the boost?? A while ago I did some tests with a aftermarket boost gauge (don’t have it now) is when I just unplugged the solenoid the car ran the same boost through the rev range as to before with the two stage sh1t.
is this normal?
Sounds like your car has a R32 GTS-T Acturator fitted which runs 10psi
i am new to the skyline scene and i am looking at raising the boost... but i am more interested in like 10-11psi not 7-8.... i put a bleed of valve on for the moment becoz i am going to do all my mods in one hit... what i did was run the bleed of valve and diconected the soleniod by running one peice of vacum line like a loop from both of the nipples on the soleniod? becoz this is no longer connected to the wastegate shouldnt it not effect the controlling of the boost at all ?? but yet i can still only make 5 psi ? any help regarding would be super... thanks mick
i believe the r32 runs 7psi all the time.
Im not quite sure about that, are you talking about stock or modded - im assuming stock. But my brothers run 11 psi stock. I believe its due to the turbo being ceramic.
  • 3 weeks later...
To add on my 2 cents...
You don't need the solenoid, yank it out. Connect the tube that connects to the top solenoid straight into the T piece that the bottom tube from the solenoid connects into... remove solenoid, throw it over your shoulder.
I also have a boost gauge with about 2m of tubing on it, so it allows it to hit the (so I'm told) factory max boost of 10psi. Works well. It's the stock turbo and no EBC, so I have no need for bleed valves or whatnot until I buy something better.
Hmmmm... as far as I'm aware, the 33 was supposed to be 10psi max as well. *shrugs* It works, so I no complain. :rolleyes:
Also, I believe mine is totally stock. The car was not really fiddled with when I got it. Only got mags, suspension and cat-back... no real power upgrades to speak of, so it'd be a wee bit weird if they changed the actuator spring... *scratches head*
Anyone with a definitely stock 33 turbo want to remove the solenoid from the picture and see what happens?
You can only get as low boost as what the actuator opens the wastegate at.
The solenoid can only "trick" the actuator pretending there is less pressure there than actually is. Hence if you remove the solenoid altogether (connecting lines together) you should only get 5 psi (or the base setting of the actuator).
If you pull the hose off and leave them dangling then the actuator won't sense any boost and you will get heaps of boost, apparently the wastegate will open eventually due to the force of the air acting on the wastegate (depends on the spring tension in the actuator) anyway you will probably see 20psi or so before this??
And see your turbine spit out into the exhaust 5psi before that. :P
My 'line is an early 94, so since I'm getting 10psi, it may be that I got an actuator off a 32 turbo. *shrug*
I'm happy with it at that until a new turbo comes along.
Yeah - I wasn't suggest you do that.
Just checked on mine, the solenoid -ve was the black and the white was carrying the +ve 12v
Might try this mod, seems fairly good for some extra low end. Why would Nissan put such a thing on? Traction issues maybe...? Cant see it really helping the engine to last longer..
I was told to get a FMIC before playing with boost but this seems fairly harmless as the car is running the higher boost at higher rpm anyway..
Any thoughts?
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
