The other option for removing the 2 stage boost is to pull the two hoses off the solenoid and just use a small piece of pipe as a joiner. As long as you leave the original pipe with the restrictor in it in place you will get the "hi boost" pressure all the time. (about 7 or 8 PSI)
What you can also do is replace the small hose with the restrictor with a piece of vacuum hose and play with the size of the hole in the joiner pipe. I found that filling it up with "Lumiweld" (aluminium solder) and drilling it to 7/64" (2.78mm) I get a momentry spike to 12PSI which drops off to 10PSI and eventually decays to about 9PSI by redline.
The difference in the driving experience is fantastic.
Even just getting rid of the solenoid out of the system and getting standard hi-boost all the time makes the car much more fun to drive.
150% recommended.
I have recently purchased this Skyline and decided to follow these simple instructions. The Skyline had an adjustable boost control and either way I turned it to Positive or Negative it had the same boost Max 9lb.
Being new to the Skyline movement from the humble SS Commodore, I have been converted. However, not being a mechanic I placed all the hoses after removing the boost controller back to the standard solenoid and re-wired the white wire to the body of the car. I then tested the theory by taking the car for a spin around the block and it spiked to 20lb boost, it scared the S@#@ out of me because the Skyline backfired and I thought I blew the turbo, it was only for a split second then i backed off straight away. I got back home and found the hoses were in the wrong position.
Now the car is pushing 7 - 8lb and it is smooth. Could someone please tell me what the hell I did wrong. Have i damaged anything that will haunt me later. Im good with V8's but not with these TURBOS.
Chris , Sydney. :flamed: :throwup: :Bang:
  • 5 weeks later...
hi im new to this business and my skyline i recently perchased at this setup already installed but my r33 has a stock 34 cooler and a custom air intake and 3' exhaust. with this boost setup my car runs just under 10psi.
is this normal?
if so can i run a switch of the ground wire and would the off position run the stock boost setup?
thanks for your time anyone?
i think what would have happend when your car ran 20psi, is that the actuator wasnt connected and it just boosted infinatly.
ive set up a switch on my car, but found i loose around 50km per tank of fuel in economy if i run the 7psi constant thing so i switch it for having fun then switch it back off.
Guest RedLineGTR
Can’t you just disconnect the solenoid via the plug? I know it removes the two-stage boost but at what level does it keep the boost?? A while ago I did some tests with a aftermarket boost gauge (don’t have it now) is when I just unplugged the solenoid the car ran the same boost through the rev range as to before with the two stage sh1t.
is this normal?
Sounds like your car has a R32 GTS-T Acturator fitted which runs 10psi
i am new to the skyline scene and i am looking at raising the boost... but i am more interested in like 10-11psi not 7-8.... i put a bleed of valve on for the moment becoz i am going to do all my mods in one hit... what i did was run the bleed of valve and diconected the soleniod by running one peice of vacum line like a loop from both of the nipples on the soleniod? becoz this is no longer connected to the wastegate shouldnt it not effect the controlling of the boost at all ?? but yet i can still only make 5 psi ? any help regarding would be super... thanks mick
actuator as in boost solenoid?? so does this mean if i get an r32 one it will run 10psi...is it an easy fit?? i think id preferr this to a bleed valve.
i believe the r32 runs 7psi all the time.
Im not quite sure about that, are you talking about stock or modded - im assuming stock. But my brothers run 11 psi stock. I believe its due to the turbo being ceramic.
  • 3 weeks later...
To add on my 2 cents...
You don't need the solenoid, yank it out. Connect the tube that connects to the top solenoid straight into the T piece that the bottom tube from the solenoid connects into... remove solenoid, throw it over your shoulder.
I also have a boost gauge with about 2m of tubing on it, so it allows it to hit the (so I'm told) factory max boost of 10psi. Works well. It's the stock turbo and no EBC, so I have no need for bleed valves or whatnot until I buy something better.
Hmmmm... as far as I'm aware, the 33 was supposed to be 10psi max as well. *shrugs* It works, so I no complain. :rolleyes:
Also, I believe mine is totally stock. The car was not really fiddled with when I got it. Only got mags, suspension and cat-back... no real power upgrades to speak of, so it'd be a wee bit weird if they changed the actuator spring... *scratches head*
Anyone with a definitely stock 33 turbo want to remove the solenoid from the picture and see what happens?
You can only get as low boost as what the actuator opens the wastegate at.
The solenoid can only "trick" the actuator pretending there is less pressure there than actually is. Hence if you remove the solenoid altogether (connecting lines together) you should only get 5 psi (or the base setting of the actuator).
If you pull the hose off and leave them dangling then the actuator won't sense any boost and you will get heaps of boost, apparently the wastegate will open eventually due to the force of the air acting on the wastegate (depends on the spring tension in the actuator) anyway you will probably see 20psi or so before this??
And see your turbine spit out into the exhaust 5psi before that. :P
My 'line is an early 94, so since I'm getting 10psi, it may be that I got an actuator off a 32 turbo. *shrug*
I'm happy with it at that until a new turbo comes along.
Yeah - I wasn't suggest you do that.
Just checked on mine, the solenoid -ve was the black and the white was carrying the +ve 12v
Might try this mod, seems fairly good for some extra low end. Why would Nissan put such a thing on? Traction issues maybe...? Cant see it really helping the engine to last longer..
I was told to get a FMIC before playing with boost but this seems fairly harmless as the car is running the higher boost at higher rpm anyway..
Any thoughts?
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
