ah ok, i thought maybe the solenoid was to restrict it to 5 from 7. ah well there goes that idea. will keep shopping for a 10psi r32 one. Any diagrams going around to disconnect it once i get the 32 one?
I think i did one a few pages back :down:
Hi!
There is no restrictor as such.
The actuator is subdued to the manifold pressure unless the car reaches 4500 rpm or so.
At this point the solenoid kicks in and reduces the pressure on the actuator, tricking the actuator into 'assuming' the boost is lower than actually is.
The actuator is a 5PSI type ..
Cheers,
Andrew
Edited by Torques
once you have the 10psi actuator the solinoids will be obsolite wont they ??
  • 1 month later...
this mod has been around for a while now, how have peoples solenoids held up with being held open 100% of the time when it should normally be momentarily? any solenoid failures?
...I'll second that. Anyone?
  • 1 month later...
Attention R34 owners
I have just done this mod without cutting or stripping any wires and it works.
1) Unplug the solenoid
2) Feed wire through the ecu plug side and reconnect plug. (see pics on post 231 on pg12) ignore warning as he had a different problem (see post 355 pg18)
3) Turn ignition on but not engine
4) R34's have an earthing strap from the engine that earths on the chassis just below the solenoid via a spade plug. Attach other end of wire here.
5) You will here the solenoid 'click'.
6) Drive around on high boost below 4500 revs.
Took less time to perform the mod than it did to write this post :P
Side note for those who want a switch for fuel economy. There are 3 pedals in the drivers side foot well. The far right one is the fuel economy switch. It's a good switch as it's progressive and not just an on/off switch :P
could some one please send me a pic of how the vac hoses are ment to be connected to the solenoid because mine has been bypassed and i want to connect it back up.
Here you go ...
Edited by Torques
Anyone with an R34 that has done this and felt a difference, before you did the mod, did you see the boost change at 4500 rpm? Using the stock gauge, once I hit max boost around 2800, it doesn't change until the redline.
  • 1 month later...
  • 3 weeks later...
Is this useless if you have an EBC?
Noobiest question Ive ever asked lol.
An EBC is basically a more advanced/adjustable version of the stock solenoid. Normally to fit a EBC the standard solenoid would be removed/disconnected.
if you unplug one of the hoses and block it it tricks the solenoid into keeping the wastegate closed for longer coz its getting an inaccurate reading,
by doing this i am running 11psi and only takes 30 seconds to do. seems pretty safe and dont get any boost spikes as far as i can tell
I had mine off and it definately did the same thing.. I ended up connecting it back up and doing it with the wire, but i am hitting 9 sometimes 10psi and i have only got a cat back and pod. Cant wait for my turbo back..
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
