Ok so I did this mod 3 days ago, I have a r34 gtt sedan, doesn't come with a boost gauge, the
Mod worked great then yesterday it felt like it was back to normal, anyway I read some1 posted bout joining the 2 connecting hoses on the solenoids together, so I've done that and my car goes like a rocket,my car has been converted to manual and also had the turbo replaced with another 34 turbo but was told it was reconditioned and had a steel wheel, my car doesn't back fire at all and it feels like its running more then 7psi... I will get a boost gauge ASAP but have I done something that I'm going to regret or not cos I'm loving this power....
I also did try disconnecting the bottom hose on the solenoid to see what it was like and I hit some kind of cut at around 4200rpm so I put it back on... But now I've connected these hoses it feels amazing and has no sign of cutting out or leaning out, it's real smooth, feels like its hitting full boost at around 3k, is it possible that I have a 32 actuator in my turbo? Also I still have the black wire earthed, only other mods is a k and n pod, still stock exhaust...
Yep.
1) Get a boost gauge ASAP.
2) If you disconnected the bottom hose and didn't plug it, then you probably had infinite boost (til stuff go boom) cause the actuator would have no pressue to it and wastegate wouldn't have opened.
3) You could have a 32 actuator. (pics?)
Scroll up ^^^ to post #608 the first pic shows an actuator. (the brassy coloured thingo with the hose going to it)
Looks to be an R33 one. R32 the hose comes straight out the side. (down I think)
Edited by Not a Pulsar
Between turbs and strut tower. Easy to see if your head is the size of a tennis ball. :rolleyes:
Look closely and you will see it.
  • 1 month later...
Finally got around to doing this today. Car feels to pull a but harder when coming out of a corner in second. Haven't had the chance to take it for a big hit yet.
If it's not done correctly it will only boost to ~5psi correct? On my stock 34 boost gauge she sits a little over halfway to +1 which would be around 0.8 bar is that right? Only mods are full 3.5in turbo back exhaust and FMIC so this would constitute slightly higher boost than normal right?
fun, cheap little mod
If it's not done correctly it could go to infinite boost or 5psi.
Personally, I would not trust the factory gauge - whilst the boost sensor reads accurately, it's impossible to get an accurate measure on the actual boost you're reading. If you are hitting 0.8 bar that's 11.6psi - which may be on the high-side.
With a 3" exhaust & FMIC - without this modification - I was hitting around 8-8.5psi through the mid-range. Even with a 3.5" exhaust, I wouldn't have thought you'd be hitting 11.6psi - but maybe it is. I ended up fitting a 10psi R32 actuator to get a steady 10psi (0.68 bar) - which is safe on the factory turbo. I quickly hit R&R when I let the factory boost solenoid connected as well so this was dropped.
Either way - yeah, maybe temporarily (or permanently) drop an aftermarket boost gauge on there, I'd be surprised you not hitting R&R if you are hitting 11.6 psi..
Nah definitely not getting infinite boost as it peaked just over that halfway mark on the gauge as I mentioned. Yeah I know the factory gauge is pretty dodge - I wouldn't mind a proper accurate gauge, I think it would be wise if I eventually get a nistune. Do you know if it's possible to just change out the factory boost gauge and leave the others (apart from looking a bit meh)?
I guess the question is - those who have done this mod and are still using the factory R34 boost gauge, where does ~5psi sit? Pretty sure I have done the mod correctly....it doesn't look like rocket science.
erm...whats R&R :blush:
Got it, thanks.
It feels fine but will get more of an idea of the changes when I take it on my usual circuit.
I know it has been asked already but is there any longevity problems with this mod? I'm sure there are people that have been running it for a number of years now..
Got it, thanks.
Runing this mod for 1 1/2 years, daily no problem.
Yep all good for me too, car seems to have a little more punch around the 3k rpm mark but no change higher in the rev range. Induction noise is almost bordering on annoying down low.
Would recommend this to everyone with stockish setups.
  • 1 month later...
Hi All,
I did this mod on my stock 96' S2R33 & now she wont rev past 2500rpm.
I freaked out (cause I just got the car), &put it back to original(re joined the wire),
But still only reving to 2500rpm...
Please help, I'm new to skylines..
What could be the problem??
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
