I have a pair of RB26DETT Bovs - great upgrade for RB25 - more robust construction - bolts straight on to existing flange - just needs an adaptor for the outlet hose as GTR is bigger.
Some surface rust on one of them (if you know where they are mounted on the GTR you will know why) but both are in good working cond (money back guarantee on everything I sell).
The better looking one $55 - the other $$45 (should clean up ok). Please PM me if interested.
https://www.sau.com.au/forums/topic/428973-rb26-bov/
  • 4 weeks later...
