Looks like an awesome time everyone!!!
I'm hoping to have my nugget done so I can join you all some time soon! :yes:
Didn't know you were on the SAU forums too.
More Evo's! Forum should be renamed Evos Australia :D
@Luke, That wallaby was waiting for you lol, didn't run across until you were closer
Haha, Im everywhere.. :woot:
still have a 1/3 of a tank left.
Was laughing at the GTI, pushed it all day and covered 350kms... DTE was still showing 400+ when we got home! I would have been on my second tank of ethanol by then haha
The GTI is awesome... Needs an exhaust, intake and tune though!
Edited by Tonba
Hopefully should have the video done by tonight chaps. I done around 2 minutes of it last night (Which still took from 6:30 - 10:30!) and was buggered and went to bed!
Looks good so far though! Still got a metric shittonne of footage to go through and chop up, etc.
10% intrest each week on repayments haha just kidding glade I could help
PM your bank details champ!
Hey glad to help.
Sounds like that servo guy was a cock!!
He was Okay, The female manager was the one needing some cock
yup cards are safe :laugh:
I know, wtf was with that.
saw it, thought, hes not going to go the other way, bet hes coming straight across.
corners were fun on the way back.
whats that at terry?
your organising a hill climb? ;) thatd be a dream come true! that was my local sunday drive!
Luke is handling the Mac Pass event.
Matt, Carmen and Luke are handling Hillclimb/s
Exciting year ahead! Terrific to see how active Newie and ACT are! You have our every support!
Was a great day out guys. Thanks for having us along. Not the usual pace that we keep around the mountains, but still a fun trip. Was great to put some names to faces. :)
Great to see you Tony - but we could have chatted more about what Qld and NSW are doing in future.
You the man! Looking forward too it!!
Except Benji.
:rofl:
Trivia...
At home, Maria's Bimmer does not set off the EVO alarm.
Nor does the Maxima
Nor does the Postie's bike
My GT-R sets off the EVO alarm.
Yesterday at the truck stop...
* Other EVOs did not set off the EVO alarm
* Harleys did not set off the alarm
* R33 GT-Rs and GTSTs did not set off the alarm
* R34 GT-Ts did not set off the alarm
* The BsB R34 GT-R V-Spec did set off the alarm
*** The alarm was set off by - you guessed it - the R34 GT-R V-Spec II Nur with again, an N1 block. So is it a particular frequency?
Trivia...
Nor does the Maxima
Did my Stagea set it off on Sunday ?
Then there was also the unmarked copper heading up to the meet that jumped out infront of you
Agreed, the run home was also good.
I looked in my re-view mirror when we were towards the bottom of the putty and there's Terry, must of really "tested" the Evo on the way back :)
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
