Engine: Walboro intank pump, aeromotive fuel reg, Just purchased all speedflow 200 series hose and fittings for e85, custom plenum, 90mm throttle body, sard fuel rail, custom exhaust manifold, garrett gt3071r turbo, 38mm gate, front mount cooler, gfb boost controller, all blue silicon vaccum hosing, superspark coils, microtech lt12 yet to be wired in, microtech x6 ignition, cometic head gasket and all multilayer steel gaskets everywhere else.
Exhaust: turbo back 3 inch stailess steel mandrel bent.
Suspension: tein coilovers and adjustable arms
Wheels: work emotion xd9 18x10 +18 all round with 265 archilles semis
Modifications: full vertex kit, nardi steering wheel, battery in the boot, fibreglass bonnet and wide gaurds, boot wing removed etc
Stereo Audio / Visual: Pioneer cd player with pioneer front and rear speakers
Estimated Power: once its all running and new injectors are in looking for close to 400hp on e85
Move that 4dr POS and show us more 121!
jks.. Looks good, not usually a fan of 'Mexican' fitment on 32's, but those XD9's really pull it off. Engine specs sounds pretty good too, any plans to 25 it?
Edited by colourclassic
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
