Nistune shits all over greddy emanage in terms of what it can do.
What are your goals for the car? If you plan on going big in the long run then you will want to be looking for different specs than if you are planning on keeping it relatively stock with only the usual mods and maybe a small turbo upgrade (and associated mods).
But at the end of the day, you are best of speaking to the shop you are planning on having do the tune and see what they recommend. Any ecu is only as good as the person who tunes it
Thanks piggaz and derp derp... Looking at giving it to Willal racing and just getting it dyno tuned and remiving the boost controller and just getting the most out of the car without touching the internals.. I like the look of
The greddy ultimate... Nistune I heard is very limited ?
Depending on how much power you want...
Nistune can easily achieve over 300RW kW's for a GTR.
Considering your engine is stock, Nistune is enough.
If you want to push it further, go for an A'PEXi Power FC.
  • 1 year later...
Ok I ended up installing the Nistune which is great I am now getting 310rwkw have I maxed it out? As I will he going for more hp is it time I changed I was thinking the haltech.. what can it do that my Nistune can't?
What turbos are you running? STD ones sort of max out around 300KW.
My V-Spec2 GT-R has Nistune with...........
  • HKS Boost controller
  • 3" Turbo Back HKS Exhaust with Hi-flow Cat.
  • 720cc Sard Injectors
  • Upgraded Walbro Fuel Pump
  • Splitfire Coils
  • Nismo AFS
Dynoed at 271rwkw's on a pretty safe tune and I'm very happy with it courtesy of Unigroup Engineering.
Next step is upgraded dumps, better turbos probably N1's (Mine are stockers) Adjustable cam gears.
Not sure if that's all I need to get to about 320rwkw's.
Cheers,
Bob.
I am making 600+ hp with nistune.
It is all about the resolution. Nistune is 16x16. All good standalones are 32x32 minimum.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
