Hi all,
I am currently in the middle of Building/Converting an RB30DET S14 Facelift and require some opinions from people with experience.
I am aiming at a 400-450Hp (300-350KW) build, I am mid-way through and need some help deciding between a few items, I am not to stressed on the money side of things but prefur not to be paying out the ass for unnecessary items that dont give much power output.
This is the build I have in mind and wondering if there are any things that people would change or would rate.
RB30 block from VL auto Commedore
(Honed and Dipped)
Rb25DE head
TopMount Manifold with 44MM wastegate
750-850cc Injectors
Ultra Spark Coil packs
Garret Turbo, either GT35R, TA3410 or GT3076. ( has anyone dealt with chinese rip-ops of these turbos and know if they are anywhere worth it? have been told not to bother but never heard of anyone having one blow up on them )
Have a crank collar, New water pump, Oil restricters etc
I have a mate building this with me who is definately more switched on when it comes to RB's so ignore if I sound a little new to this.
This is where i need help on deciding things.
- I have read RB20DET gear boxes can only handle upto 400hp safely so i'm assuming a 25DET one will be needed?
- Also I need help deciding on what internals to replace with aftermarket parts, am I right in saying cams would be a better investment than pistons/Conrods?
-Should I replace the valves and valvesprings in the head as I read they are 400HP capable and would rather be safe than sorry. also does this make a power increase?
-Are N1 Oil pumps worth it? there are very mixed feelings on these I have found, I am not going to be doing limiter raping skids or anything just after a nice sounding car with decent speed
There is a place near where I live (Christchurch, New Zealand) that I have heard great things from when it comes to dyno tuning and have heard they provide there own ECU's so thats where I will be going at the end of my build.
I am open to all suggestions so please feel free to post your builds and power outputs.
https://www.sau.com.au/forums/topic/429051-another-rb30det-post-need-opinions/
For that power figure I would go with a 25 NEO and save a lot of work building a motor
Have a look in the Forced induction section for dyno results
NEO motor already has strong rods and N1 spec pump as well as better flowing head etc and lots of cars making good power on std internals
But that just my opinion
Guest
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
