Item 1.
Genuine Rays Volk TE37 in White, 5 x 114.3
- 18 x 8,5 +30
- 19 x 9.5 +35
- Have just returned from slight gutter rash being removed, sand blasted and powder coated
- Stickers available from eBay
- $250ono
Item 2.
Genuine Exedy Clutch
- Genuine Exedy OE Replacement (Full Faced Organic) Clutch / Drive Plate (NSD098U)
-$100!!!
This plate is found within the following Exedy clutch kits:
  • Exedy NSK-6531
  • Exedy NSK-6531HD
  • Exedy NSK-7056
  • Exedy NSK-7056HD
  • Exedy NSK-7297
  • Exedy NSK-7297HD
  • Exedy NSK-7377(SMF)
This Listing Suits The Following Application(s):
  • Nissan 180SX RPS13 (SR20DET, 01/1991 - 12/1998)
  • Nissan 200SX S14 ADM (SR20DET, 10/1994 - 03/2000)
  • Nissan 200SX S15 ADM (SR20DET, 01/2000 - 01/2002)
  • Nissan 300ZX Z31 200ZR (RB20DET, 10/1985 - 06/1989)
  • Nissan Cefiro LNA31 Attesa Cruising (4WD) (RB20DET, 08/1990 - 08/1994)
  • Nissan Cefiro R©A31 (RB20DET, 09/1988 - 08/1994)
  • Nissan Laurel R©C33 (RB20DET, 04/1989 - 01/1993)
  • Nissan Pulsar RNN14 GTI-R (SR20DET, 08/1990 - 01/1995)
  • Nissan Skyline HR31 JDM (RB20DET, 08/1985 - 05/1989)
  • Nissan Skyline HNR32 GTS-4 (RB20DET, 08/1989 - 08/1993)
  • Nissan Skyline H©R32 GTS-T (RB20DET, 05/1989 - 08/1993)
  • Nissan Skyline E©R33 GTS25-T (Series 2) (RB25DET, 01/1995 - 05/1998)
  • Nissan Skyline E©R33 GTS25-T (Series 1) (RB25DET, 08/1993 - 01/1995)
Item 3.
OMP Race Seat
- FIA Stamped
- Purchased from Revolution Racegear
- Comes with Revolution Racegear side mount brackets
- $400ono
Item 4.
Just Jap Seat and Passenger Rails
- Made for comfort
- Custom made passenger seat rails
- $150ono
Item 5.
HKS EVC 3 Boost Controller
- As Pictured
- $200
- All items are in Clayton, Victoria 3168
- I am willing to post, please PM me
- Discounts for buying multiple items
- Make an offer
- 0421 489 894
    • All of them are missing. I'm an Elec. Eng. but mostly do software. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
    • Correct, I didn't put GT-R in the same category in this thread, incase I offend anyone. But @GTSBoy  knows my true thoughts on all Nissans.
    • Get more oil pressure sensors. I have 3 purely because trust no-one. It would be worth checking (if not already) if it happens on every shift. Like boring, 2-3 shifts at 60kph making 10kw with no obvious G-force on a shift with mega power. Does it still drop? Does it drop less? What if you shift at 5000rpm or what have you with no load?
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
