  • Replies 149
Sounds a bit arbitrary. You would have to be experiencing quite a few G's as well. What is fairly common is loss of oil pressure on slicks with GTR's, so with those tyres of yours you would be running close to the limit, but given the oil cooler should be fairly safe. Road tyres (like mine :)) would be fairly safe from what I have found in my searches on the topic.
To be honest it shouldn't be too hard to simulate the oil motion in the sump to determine the critical sump level. Might waste some time on that when I'm done on the conrods.
What has Ben had to say about it (since you started dropping names)?
BTW I have been black flagged due to loss of support from the finance manager, who managed to drop another $1500 on furniture yesterday, so have a good weekend.
Geoff.... Furniture???? I know your pain, i just spent about 8k on crap for the house :)
At the minute there may be someone coming with me on the Friday to help dial in my susp setup for the Sprint on Sunday, if he isnt able to make it then you are welcome to come up and ride shotgun in my car, hell even do a few laps behind the wheel if you can squeeze into my momo seat :D
INANST...with the std fuel pump, i only ever got fuel surge probs when the tank was extremely low, as the std tank (in the R32 anyway) is pretty well baffled.
With an aftermarket fuel pump installed it is very dependant on how it was installed....as their isnt any real science in installing properly 90% will still run fine with no fuel surge until you get very low on fuel...so not a concern...and consdiering what fuel consumption is like, fill the thing up before you get there, as i normally go thru about a tank and a half for a full day at Eastern Creek or Wakefield
I can add/delete names pending people confirming, but to get an idea of who is in. Bold indicates confirmed.
For the Friday open day:
- Adzmax ... next time :)
- INASNT
- GTTR34
- Snowman
- Scotsman
- ferni , needs some more convincing :D
- Roy
And for the MSCA Sprint on Sunday:
- Adzmax
- GTTR34
- Snowman
- Scotsman
- Roy
If we can get 6-10 people to the Friday it will be great :)
grrrr wish i didnt have to work nite shift :)
might try n make it there just to watch u guys at least for a few hrs
btw ur better off staying in wangaratta if u wanna hit the turps... better pubs
also look out for the 2 r33 gtrs that reside there :)
So am i the only one going on the Friday? :confused:
I may just drive up Sunday morning for the sprint
If so i may stay home and use the Friday/Saturday to fiddle with my car as i dotnthink i will have my car back by this weekend... nothign that wills top me form driving it, just little things that need attention and sooner would be better then later
Roy - at this stage Im still keen to go up on the Friday. But it looks like I wont be competing on the Sunday. Thats unless a miricle occurs and my parts arrive for my gearbox before then. But I still want to get to know the track so I'm thinking of punting my completely stock rex wagon around Winton on Friday for a bit of fun.
Anyone else still keen to come up on Friday. I think Adzmax was still interested.
Just rang winton, the Friday is a goer! :)
As Snowman posted, you need:
- YOUR OWN helmet (cant be hired on the day)
- Car does not need to be registered, jut roadworthy
- No Passengers in cars
- Fire resistant head to toe clothing, 100% cotton shirt and pants are fine.
- No sepcial drivers licence requirements (i didnt enquire about a suspended licence is acceptable)
Day goes from 10am to 4.30pm...should be a good fun day for the princely sum of $100 inc GST
The reason i rang Winton was to see if they accepted passengers... sorry KamikazeR33, ill shout you beers Friday night if you care to jockey the camera for post event pow-wow sessions :D
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
