Hey everyone,
Car is finally up and running well.
So I have decided on finally fixing the broken exhaust.
I have a rather large crack where the exhaust joins to my mid muffler.
Looking to replace the muffler with a aftermarket piece and sorting this issue out.
Any recommendations on a 3 inch mid muffler for my exhaust.
Something that is not so restrictive but nothing over the top loud.
Cheers,
Daniel
https://www.sau.com.au/forums/topic/429064-exhaust-muffler-suggestions/
just put a second hand zorst on my 32 2L-t
3" to a huge straight through mid muffler, then going to a 31/2" and a small straight through cannon, friggin a lot quieter than I thought, and only $200 from epay
thanks again shifty
Just found them online for $120 delivered
I think it is the one someone else suggested because they have a nice deep tone.
http://www.ebay.com.au/itm/HOOKER-AERO-CHAMBER-MUFFLER-3-CENTER-CENTER-21506-HKR-/200608424848?pt=AU_Car_Parts_Accessories&hash=item2eb531a390&_uhb=1
I also just emailed the guy from AES about how much he would charge as well.
I'm also looking at fitting a mid muffler to my exhaust, since fitting the 6 boost with the gtx3076 the exhaust is so much louder than it was with the stock turbo and manifold on there.
Currently I've got a 3" stainless dump off the turbo, 3" cat which I'm unsure of the brand or the quality of it, the mid sections a straight through pipe with the only muffler being a x force varex muffler at the rear but if you drive around in the quite mode it sounds utter shit!
Good thing the short mid section is flanged so it's easy enough to get something made up. I'm prob leaning towards a stainless straight through magnaflow. I've had the aero chambers on my v8's honestly not to sure if I'd like that sort of deepness coming out of a skyline. Hmmm. Any other suggestions on mid mufflers?
Kind of hard to get measurements whiles it's on the car.
But I got under there with the tape measure and got the following measurements.
Length = 29cm (11.6inches)
Width = 24 to 24.5cm ( 9.4 to 9.6inches)
It also seems my current design is.
3 Inch centre inlet
3 inch off centre outlet
All of the designs I could find on the Hooker Aero were either
3 inch off centre inlet with a 3 inch centre outlet.
or
3 inch centre inlet with 3 inch centre outlet.
Not sure what to do in that situation
Any advice would be great.
Otherwise I guess I can just take this to AES and they can hook me up with a custom made one.
3 Inch centre inlet
or
Are these mufflers directional?? Can't you just turn the muffler around?
