(mods if this is in the wrong section please move)
Hi guys, in a bit of a dilemma. The only tuner up here in Darwin is retiring at the end of this month and my car won't be finished until December.
How do you guys recommend getting a tune done?
There is other workshops up here with Dynos but they do not do tunes.
And sorry for posting a random question such as this haha.
Cheers
https://www.sau.com.au/forums/topic/429090-how-to-get-a-tune-done/
Cheers
Sorry for the obvious question but do you have a tunable ecu if so what kind?
Being in a remote location must be a pain in the ass lol... Either someone needs to come to you or you need to get the car to someone... I guess that is the obvious answer though :P
how modified is the car? if it's just running all stock gear, i.e. injectors, afm, turbo why not give Toshi (forum biz trader) a call?
Just get an off the shelf reprogrammed ECU (he installs his own EPROM on the board).
Car will be running a hypergear turbo and apexi powerfc. All other mods such as injectors and afm will be done.
I haven't purchased the ecu yet so that can be changed depending on what would be of benefit.
Kinda crappy situation and there is nothing I can do about living in Darwin. Army sorta posted me here indefinitely haha
Get an adaptronic via hypergear, he can sell you a turbo and ecu combo for close to 2k depending on what sort of turbo you are getting... It also means no AFM which is win win.
As noted by other guys, best bet is to book a good tuner to come for a holiday with his wideband and do some road tuning along some of your no speed limit highways. It will probably be a days work but some tuners might be keen just for the experience. Surely it would be fun...
PM DVS JEZ, he is the nicest tuner I have ever met and he puts a lot of care into his work. Hopefully he can sort you out.
Have you not heard the term AWOL? Its there for a reason :P
Yea adaptronic would be my preference but I just assumed seeing as no tuner up here now that the easiest ecu to get tuned would be powerfc.
I have a bit of time before I need it tuned so can probably look into it.
And I bet if I could find someone to come up here there would be a lot of interest from the other guys here as well who are in the same situation
IF this was the case get a list of the cars and the mods each one has and you will probably find a tuner will come to you and do a heap at once! Well i am sure there are some that are willing as long as there are multiple cars and there is money to be made!
The other aspect to the "be prepared" thing is to actually be prepared. By this I mean, make damn sure that your fuel pump is up to scratch, your injectors are clean and functional, that every other thing that generally goes wrong with cars on the dyno during tuning has been thought of and some action taken to check or fix anything that could be wrong. That way you won't have your tuner come up for no result, or sitting twiddling his thumbs while a collapsed cat converter is swapped out, etc etc.
If you can follow my thread and buy exact branded injectors and fuel pump I can give you a tune file for the adaptronic ecu, which should run pretty close.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
