Hi guys, just looking to clear up a few things. the ye olde search fuction has failed me. lots of info of anti theft set ups but looking for motorsports/Cams legal setup
I'm looking to install a kill switch, obviously.
i want the most simple setup i can get away with, what do i need to be cutting? its a 33 so battery is still in the boot, do i run a switch in the engine bay in the pos cable off the alternator and run one pull cable to the scuttle panel infront of the drivers A pillar and a second cable into the car mounted to the cage or somwhere so its able to be pulled from outside and inside?? should i be cutting from the battery instead? the kill switch i looked at is a grayston unit with the extra pins and resistor etc, do i have to cut the ign out aswell?
i could of sworn i saw a install on here yonks ago by maybe (duncan)?? it looked as tho the battery was in the boot, the pos cables were run up to behind the handbrake area to a plastic jaycar spec box to the kill switch the back to the battery. maybe i dreamt it up
any help greatly appreciated, cheers
my 32 has had battery moved into the boot, positive cable is run through the cabin via the battery switch,
and the auto elec used the alternator warning light to stop the car when the switch is turned off.
the alternator warning light is what excites it to charge, so if it's switched off it kills the car, only drama is it
can also kill the alternator..
Cheers
Kill switch needs to cut the positive battery lead and the positive feed to the alternator, doesn't have to cut the ignition separately. Cutting the alternator warning light wire will only stop the alternator from exciting it won't stop it from charging while driving.
It did on my car, even had to wire the warning light to my digital dash, because the alternator would not charge without it,
no charge from the alt + cut battery power equals car wont run..
Unusual, most of the time you can get the alternator to kick in by revving it hard enough even without the globe if it hasn't been sitting for too long and has held some residual magnetism. I would still recommend doing it with the actual positive feed to the alternator.
Yeah that was on Neil's race car (http://www.skylinesaustralia.com/forums/topic/341836-neils-r33-gts-t-build/) It was run that way to retain the standard undercar main positive to the starter and front, so basically the + terminal runs to the switch near the seat, and then back to the boot. There are shorter was to cut it if necessary. It uses a dual pole switch to cut both the main battery and the main ignition (via a big relay).
I've used a similar cut off in my race car (ie relay to cut ignition) but I'm not really happy with it in either car because the relay will eventually drain the battery unless the kill switch is pulled.
I'd love to hear a better way to do it without hacking up factory looms too much.....without the ignition relay the alternator obviously keeps the car running even if the battery is isolated. Has Damo or someone else knowledgeable got an idea?
BTW if I was doing a new car now I would just use 2 electric switches killing both legs of a relay (one +, one -). Easy to run the extra wires and no need to run full power all over the car. A switch like this would be appropriate for the external kill:
http://www.jaycar.com.au/productView.asp?ID=SP0786&form=CAT2&SUBCATID=978#1
Cheers Duncan. Good to know I didn't dream it up. Burgz man and byebye (Ian?) I'm more confused now, taa. Lol who would of thought it would be so hard. SO. I can't just do what you have Duncan, run the positive cable off the battery, up the a reachable spot, to a switch, then back to the fuse box thingy in the boot, then run the ignition wire out if the ecu loom, up to the switch, then back into the loom so I'm cutting battery & ignition? Will this stop th car. Also, thinking out loud, I'm not going to be turning the car off this way unless I'm stacked and or upside down. I'll only ever be pulling the switch while the car is off to stop the battery going flat, so worrying about alternator damage doesn't worry me as that will be the least of my issues if it needs to be pulled whilst running. Question is does the car stop with ignition wire cut and battery positive cable cut? Where does this resistor come in that comes with the FIA spec switch? Sorry if it all sounds retarded. I'm good at other stuff, I'm good at dents. And paint. But bad at wires
I did nowelsy 33. Was very easy and could be made to look stock. I will post up some details when I get half a minute.
I've also done r33 gtrs with electric isolation switches rather than the normal key type.
rightio, cheers. Appreciated
Bit late in reply but if you're just after a switch to stop the battery dying, then switch the negative instead of running active wires thru the car.
Did that in my 33. No need for relays etc.
    • The prices I’ve heard aren’t that bad
    • Oh, I also meant to say that it is possible to use a venting BOV and restrict its outlet down so that it does vent enough to prevent the sututu, but vents slowly enough that the AFM doesn't see all the air at once and makes it easier to avoid stalling.
    • I'll go talk to my bank manager. Either that or my nearest western Sydney drug baron.
    • Driveability will be about the same with either externally venting BOV, or no BOV at all. Perhaps worse one way than the other, with me thinking that the definitely more flow going through the AFM through a venting BOV more likely to cause rich stalls than the perhaps more flow that the AFM might read on reversion. There is no such thing as "turbo damage" from not having a BOV at stock, or even quite a lot higher than stock, power levels. You need a big turbo with a lot of mass spinning hard getting a horrible slowdown from a slammed shut throttle before there is anything like the shaft loads required to damage things. Not an issue on small turbos. The ONLY 2 reasons that Nissan put a recirc valve onto the RB were: It is a bypass valve. It is open when under vacuum. When not on boost, it bypasses intake air forward around the compressor, which unloads the compressor, allowing the turbine to sping more freely, making the whole lot a bit more efficient when just puddling around. Throttle response should also be faster via the shorter, smaller diameter BOV pipe (when in NA, ie before the BOV closes and boost is building) which is nicer for driveability. Emissions. The reversion causes CO pulses. Eliminate the reversion (or at least, keep it away from the AFM) and you don't get that. The stalling/driveability aspect could have been tuned around, as shown one example of by dose above, if Nissan hadn't put a recirc valve on. Many many turbo engines before the RB had no BOV. They did not stall. See the RB30 turbo as an example. Nistune is definitely better than just stock ECU. It allows you to access and change things that are not excellent on the stock setup, and allows you to do mods like put decent injectors in, relocate the AFM, put a bigger turbo or even cams, etc, on, change to coil swith completely different swell needs, etc etc. All the things that you might need or want to do 25 years after the car was new. Aftermarket replacement ECU is obviously better again, because it gives you even more freedom from the constraints of the stock ECU. I won't be needing to go any further than Nistune though, for the new turbo in the 250ish rwkW region I'm going to, with big injectors, and most other things being stockish.
    • Lucky the prp block is supposed to be released next weekend
