well piggaz has seen 77 up to about 87 at united servo at rozelle. I'm not a tuner, but suspect that if your car is tuned on e85 and your buying e77 fuel (or potentially worse) then you could run into some problems.
agreed...caltex consistent. More of an issue for united.
That's not how most tuners would tune, as that's not safe.
Safe tune, variation = no problem
We test daily UNITED is the only pump fuel we recommend (caltex is average). So much so that we dont use drum.
A tuner should tune any pump e85 car to be safe on any thing down to e70 (just in case you need to fill with caltex etc) as its a very minor change in tune.... and minimal loss in hp... very minimal
I love reading these threads and learning all this shit :) I wish I had the money for a flex tune and an ECU that could handle it.
At one stage I was even thinking just going ethanol but there is only like 2 servos that stock it here and none down the coast where I do a lot of travel
The GM sensor is available for under $100 delivered now, and with a Zietronics box should work on nearly any ecu, as long as you have a spare 0-5v input... Must speak to you about that soon Trent, I have an Emanage Ultimate to flex tune. ;)
Flex tuning will definitely be getting more common in the future. I need to fit a sensor to my Fcon but I am scared of the wiring nightmare in the dash. :unsure:
Lol I am full flex so I can use pump fuel but I love ethanol so much I carry jerries of it haha
i think what people are forgetting is that if your car is tuned on e85 and your next batch of fuel you run is 70% your car will run slightly richer then normal, there is no "running lean" or "cracking pistons" situation.
I'm the opposite, was tuned on 70 and now E85 is available near home, compensation is in the ECU but going to check it properly on dyno to be safe
Yeah but Simon's point more revolves around the fact of someone not having a sensor and so on - which comes back to a lot of other posts in this thread that are quite clear
If the tune is done safely for a street car, the variation from E70 ro E85 has no bearing.
Whilst this thread is a good idea - as long as the tune is OK - It's a non-issue
Nathan what if you are going on a car trip like 3 hours away for a weekend?
Jerry cans?
Yep got 3 large red plastic ones, whether it's a trip to Winton, or going away. One day I will change from the power fc and get a ecu that can do eflex with a ethanol sensor. It's not a problem at the moment
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
