well piggaz has seen 77 up to about 87 at united servo at rozelle. I'm not a tuner, but suspect that if your car is tuned on e85 and your buying e77 fuel (or potentially worse) then you could run into some problems.
agreed...caltex consistent. More of an issue for united.
That's not how most tuners would tune, as that's not safe.
Safe tune, variation = no problem
We test daily UNITED is the only pump fuel we recommend (caltex is average). So much so that we dont use drum.
A tuner should tune any pump e85 car to be safe on any thing down to e70 (just in case you need to fill with caltex etc) as its a very minor change in tune.... and minimal loss in hp... very minimal
I love reading these threads and learning all this shit :) I wish I had the money for a flex tune and an ECU that could handle it.
At one stage I was even thinking just going ethanol but there is only like 2 servos that stock it here and none down the coast where I do a lot of travel
The GM sensor is available for under $100 delivered now, and with a Zietronics box should work on nearly any ecu, as long as you have a spare 0-5v input... Must speak to you about that soon Trent, I have an Emanage Ultimate to flex tune. ;)
Flex tuning will definitely be getting more common in the future. I need to fit a sensor to my Fcon but I am scared of the wiring nightmare in the dash. :unsure:
Lol I am full flex so I can use pump fuel but I love ethanol so much I carry jerries of it haha
i think what people are forgetting is that if your car is tuned on e85 and your next batch of fuel you run is 70% your car will run slightly richer then normal, there is no "running lean" or "cracking pistons" situation.
I'm the opposite, was tuned on 70 and now E85 is available near home, compensation is in the ECU but going to check it properly on dyno to be safe
Yeah but Simon's point more revolves around the fact of someone not having a sensor and so on - which comes back to a lot of other posts in this thread that are quite clear
If the tune is done safely for a street car, the variation from E70 ro E85 has no bearing.
Whilst this thread is a good idea - as long as the tune is OK - It's a non-issue
Nathan what if you are going on a car trip like 3 hours away for a weekend?
Jerry cans?
Yep got 3 large red plastic ones, whether it's a trip to Winton, or going away. One day I will change from the power fc and get a ecu that can do eflex with a ethanol sensor. It's not a problem at the moment
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
