So I was browsing carsales.com.au and came across this:
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=0&R=SSE-AD-1146733
Its apparently a V35x - 2008 model, with the usual 3.5L V6, and a 7 speed auto gearbox.
My understanding is that the 2008 model skyline coupes were all V36 370GT's.. This car seems like its a V35x from 2007 latest, but somehow has a 7 speed box in it...
Anyone know of this car?
It has too many kms on it for my liking, but I'd be interested to know if it's legit.
https://www.sau.com.au/forums/topic/429122-is-this-real-or-a-chop/
NFI what he is talking about.
Car is a OCT 2003.
frame # in Ad is wrong, should be CPV, as its a Coupe. Has S1 interior to back up being a 2003.
http://nissan.epc-data.com/skyline/cpv35/6826-vq35de/?frame_no=cpv35-506775
last of the v35s were made in 2006. No such thing as a V35x. And yes interior is a dead giveaway...its only a series 1.
2006 for Sedans, 2007 for Coupes. And yes, four wheel drive in some of the sedans. But this guy seems on the piss. If you're actually interested in buying the car though, call him and get the VIN, that'll answer most of your questions...
Or just click on the link I posted....
And when you Google the vin, surprise, suprise you come across 2 cached links to the original ad for it that says 2003. So he has KNOWINGLY changed it from 2003 to 2008. I assume 2008 is the compliance date? Someone who does not know Skylines that well might fall for the compliance date on the purple sticker as the build date guess
https://www.google.com.au/search?q=6u90000pv35506775&ie=utf-8&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&channel=rcs&gws_rd=cr
Could be a clean car. Price seems fairs. I wouldn't write it off just because the owner may have selected the wrong model when setting up the ad.
And if he really doesn't know anything about cars, more power to a savvy negotiator.
Play on!
That one is definitely a series 3 - has the recessed tail-lights, chrome door handles and projectors. Also it is a 70th anniversary model, as I am pretty sure they were the only ones to come with full leather.
agreed. not sure if the neon lights inside and out were S3 specific though......unless the owner ticked the 'xzibit pack' option box.
Great combo on that car otherwise. Best colour, best year, with sunroof. Tick, Tick, Tick!
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
