i've found a guy on ebay that checks the registration on cars that have been exported from Japan, only takes about 5 days for them to do it. but they do come through with the goods
http://www.ebay.com.au/itm/271234223049?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_3332wt_1386
so if they dont let you have a look at the import documents/registration papers from Japan, and you REALLY want the car. then i would advise this to be done.
its also valid for up to 4 years prior to the car being exported. mine was exported 3 years ago and all the details were still in Japan's systems
  • Like 1
i am not sure, but they send you a e-mail with a .pdf file to the original scaned document. aswell as a translated document. then they post the originals to you.
yeah $100 is nothing when it means the diffrence between a $15k car.. or a $5k car. gives you a bit of piece of mind too
  • 3 weeks later...
"R" is panel replaced. Not always accident damage, but can be indicative. Car with a body kit will have a R rating.
They can be imported and sold, check the "beware R34 gtr" thread in general discussions. Cars with Chassis damage however, should not be sold according to SEVS.
You can cover up chassis damage nd let unknowing punters drive away in an unsafe rusted chassis rail car.
Not really, the 'R' means structural repair. If cars have had just panels like fenders replaced or aftermarket bonets etc, those will be marked with a "XX" on the report and such cars can get upto 4.5 grade as they didnt have any major damage. 'R' comes into the picture when inner panels behind the outer ones have repairs on them or are bent.
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
