-7s on a 2.7-2.8 would give you the same or better response then the stock turbs on a 2.6 and given a stroker kit comes with a forged crank rods and Pistons, I would suggest the extra for the kit to get the extra CCs is well worth it for the benefits you get from it :thumbsup:
  • Like 1
The part I always find interesting with these "I want better response" threads is no seems to want to do anything that aids in response
The list of things everyone wants to do to while chasing response
Leave comp standard=wrong
Leave capacity standard=wrong
Fit larger duration cams=wrong
Fit larger turbo chargers=wrong
Even things like exhaust sizing has shown a noticeable difference in response and power right thru the rev range
  • Like 2
Ok, so we are realy gona work on the head, clean it up, up the comp, and leave standed cams with addjusterbal gears, going to set the gates up so they open at the last second and control the gate flutter with EBC, and plenty of tune time on cams and mid range, also looking at e85 options,
Lighten flywheel, stanless dumps and front pipe, are the stanless manifolds worth wile? Or port match the factory and head rap?
As Brett said, tickle the stockers. There is no gains to be made here and you won't be ripping them off to replace/fix them when they fail.
Take that money and buy yourself a front diff.
  • 1 month later...
Post to the top!!
I have -7's on an otherwise stock motor, running a HKS EVC 6 - not the colour version.
As with many others, I was under the impression that boost would be very close to stock.
As you can see in the dyno graph, boost builds very slowly (i reach peak boost 17psi at around 4800-5000 rpm)
I'll be going back to the tuners in Jan for cam gears, larger injectors and a retune, but wondering if winding in more actuator pre-load could help.
Will be turning the boost controller off and seeing what boost i reach running off actuator pressure tomorrow. I have no idea if the previous mechanics checked actuator preload before fitting them.....
Anyway, that's my story.. cool story bro
What's your cam timing
-7s will never match stock ceramics for response :(
When you changed turbos did you reset the wastegate setting on the EBC
You can also adjust the gain on the EVC 6 to get it to ramp up faster
Haven't checked mechanical cam timing yet, but will look at that after NYE.
EBC was installed at the same time as the turbos. It was reset and tuned from there.
I have played with the gain (offset), and have found a sweet spot 113% offset. Any more I lose response... However, I shouldn't need to use the offset function tbh.
I turned off the controller this morning, on wastegate pressure, boosted to 9psi. Might add a few mm of preload to the actuators to get closer to 11psi which i think is the rated spring pressure for -7 turbos.
I know that they will be laggier than stock, but they shouldn't be this laggy
Yeah 16psi at 4000rpm seems normal for -7s so there's definitely something going on with your setup. Upping pre-load seems like a reasonable first step in diagnosis (since its free :) ). Just check that their operation is synchronised with a hand pump after the adjustment.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
