-7s on a 2.7-2.8 would give you the same or better response then the stock turbs on a 2.6 and given a stroker kit comes with a forged crank rods and Pistons, I would suggest the extra for the kit to get the extra CCs is well worth it for the benefits you get from it :thumbsup:
  • Like 1
The part I always find interesting with these "I want better response" threads is no seems to want to do anything that aids in response
The list of things everyone wants to do to while chasing response
Leave comp standard=wrong
Leave capacity standard=wrong
Fit larger duration cams=wrong
Fit larger turbo chargers=wrong
Even things like exhaust sizing has shown a noticeable difference in response and power right thru the rev range
  • Like 2
Ok, so we are realy gona work on the head, clean it up, up the comp, and leave standed cams with addjusterbal gears, going to set the gates up so they open at the last second and control the gate flutter with EBC, and plenty of tune time on cams and mid range, also looking at e85 options,
Lighten flywheel, stanless dumps and front pipe, are the stanless manifolds worth wile? Or port match the factory and head rap?
As Brett said, tickle the stockers. There is no gains to be made here and you won't be ripping them off to replace/fix them when they fail.
Take that money and buy yourself a front diff.
  • 1 month later...
Post to the top!!
I have -7's on an otherwise stock motor, running a HKS EVC 6 - not the colour version.
As with many others, I was under the impression that boost would be very close to stock.
As you can see in the dyno graph, boost builds very slowly (i reach peak boost 17psi at around 4800-5000 rpm)
I'll be going back to the tuners in Jan for cam gears, larger injectors and a retune, but wondering if winding in more actuator pre-load could help.
Will be turning the boost controller off and seeing what boost i reach running off actuator pressure tomorrow. I have no idea if the previous mechanics checked actuator preload before fitting them.....
Anyway, that's my story.. cool story bro
What's your cam timing
-7s will never match stock ceramics for response :(
When you changed turbos did you reset the wastegate setting on the EBC
You can also adjust the gain on the EVC 6 to get it to ramp up faster
Haven't checked mechanical cam timing yet, but will look at that after NYE.
EBC was installed at the same time as the turbos. It was reset and tuned from there.
I have played with the gain (offset), and have found a sweet spot 113% offset. Any more I lose response... However, I shouldn't need to use the offset function tbh.
I turned off the controller this morning, on wastegate pressure, boosted to 9psi. Might add a few mm of preload to the actuators to get closer to 11psi which i think is the rated spring pressure for -7 turbos.
I know that they will be laggier than stock, but they shouldn't be this laggy
Yeah 16psi at 4000rpm seems normal for -7s so there's definitely something going on with your setup. Upping pre-load seems like a reasonable first step in diagnosis (since its free :) ). Just check that their operation is synchronised with a hand pump after the adjustment.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
