Hi All,
I have a unique problem with my new V35 Coupe. It had a JDM double DIN unit in it that was removed and replaced with a Bose premium head unit. The car is originally a non-premium spec car so had no amp. Problem I have now on getting the car is the audio is too low to hear at highway speeds (as there is no amp) and just distorts if I try and turn it up. I can get to about 21 on the volume scale before it distorts but the volume is just too low.
I am not after any top end audio system, just something for everyday driving to and from work etc. Any ideas on how to sort this out without removing the lot and going to a JDM DD or something similar? I was thinking of somehow putting a small amp in to boost levels to an acceptable volume.
Your help is much appreciated.
https://www.sau.com.au/forums/topic/429134-bose-head-unit-but-no-amp-help/
If it is a bose HU in a non-bose system, the HU can be modified to turn it into a 'non-bose' HU, but it isn't easy. They are essentially the same internals with some minor changes.
I have a bose HU in a non-bose system, and yes the volume is down compared to a correct non-bose HU, but it isn't that bad and I rarely need to run it over 20. It also shouldn't be distorting.
The biggest issue is the non-bose HU had a larger fanned heat sink for the audio amp IC. The Bose HU doesn't.
If it is a bose HU in a non-bose system, the HU can be modified to turn it into a 'non-bose' HU, but it isn't easy. It also shouldn't be distorting.
Thanks for the reply. Driving around town I doubt it will be a problem but at 110 kph, it just isnt loud enough to hear clearly. Are there any instructions regarding modifying it? And will that raise the volume?
    • (Rb25det intake manifold) I’m having a hell of a time trying to find the full part or part number of this coolant hardline so far I was given these (Below) but they aren’t what I’m looking for and was told it’s the IAR or aac valve but that doesn’t seem to be it either. If someone could point me in the right direction it’d be greatly appreciated. Or if anyone has it for sale that’d be great too. I have recently purchased a greddy manifold and I can’t seem to find my old one to pull it off.  (Front Heater Return / Water Pipe (under intake): Primary part: 14053‑21U10 (front return pipe assembly for R33/R34 RB25DET) Alternative listing: 14053‑21U00 (same pipe, sometimes interchangeably referenced)   Heater Feed Pipe: Listed as 14075‑04U00 or feed-related variant 14053‑AG500)
    • This sounds cool. But, as per usual, anything really complicated like that, that I take on, constitutes a steep learning curve that I never actually "learn". I just get it working, install it and start using it. Then, when it breaks a few months later, I've got no memory of what I did, how I did it, or even the bloody IP address I gave it. I'm having more or less exactly that problem right now. My Proxmox machine was discovered to be non-responsive, and the VMs on it were ditto. Power cycle it to a stream of loud Dell beep codes - which was unpopular at midnight, I can tell you. Move it to the lounge room so I can HDMI it to the TV for a screen, see the boot messages complaining about the /PVE/data having all sorts of LVM problems, saying it needs to be fixed manually. And I'm like....great. How am I going to work out what I need to do? At least it wasn't the stupid Silicon Power SSD shat itself. Mental note for all readers - DO NOT BUY SP SSDS! They are shit. I have had one take out an entire VM setup already, and this one could have done the same. Maybe it actually has. Cheap Chinesium shitbaskets. I won't cheap out again, even on play projects with no budget. Because my time budget having to fix shit is worth far more than the cost of proper parts.
    • I do typically agree. These days even the screens most people use have more of a boot time than the main device. However, I've seen an interesting use of the RPi in vehicle, however it involves effectively building your own OS and MBR, as then it boots up exceptionally quickly, as you don't have everything needing to start up, and you can then also run it up as an RTOS, while still having more compute than an Android can give for things like display, and processing. A very huge task that would be though for Duncan, I'm not sure that's his skill set (or Arduino programming and wiring) ha ha. If end goal is definitely just water cooling, Arduino would be the simpler setup especially for a rookie. If he wants extra display stuff though, bashing some code in Python on an RPi may be the better result for both systems.   Unfortunately the new device I'm building at work which runs a display, is too slow of a display for dashboard style purposes. More extreme low power, update only a couple of times a day type system
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
