Hi All,
I have a unique problem with my new V35 Coupe. It had a JDM double DIN unit in it that was removed and replaced with a Bose premium head unit. The car is originally a non-premium spec car so had no amp. Problem I have now on getting the car is the audio is too low to hear at highway speeds (as there is no amp) and just distorts if I try and turn it up. I can get to about 21 on the volume scale before it distorts but the volume is just too low.
I am not after any top end audio system, just something for everyday driving to and from work etc. Any ideas on how to sort this out without removing the lot and going to a JDM DD or something similar? I was thinking of somehow putting a small amp in to boost levels to an acceptable volume.
Your help is much appreciated.
https://www.sau.com.au/forums/topic/429134-bose-head-unit-but-no-amp-help/
If it is a bose HU in a non-bose system, the HU can be modified to turn it into a 'non-bose' HU, but it isn't easy. They are essentially the same internals with some minor changes.
I have a bose HU in a non-bose system, and yes the volume is down compared to a correct non-bose HU, but it isn't that bad and I rarely need to run it over 20. It also shouldn't be distorting.
The biggest issue is the non-bose HU had a larger fanned heat sink for the audio amp IC. The Bose HU doesn't.
If it is a bose HU in a non-bose system, the HU can be modified to turn it into a 'non-bose' HU, but it isn't easy. It also shouldn't be distorting.
Thanks for the reply. Driving around town I doubt it will be a problem but at 110 kph, it just isnt loud enough to hear clearly. Are there any instructions regarding modifying it? And will that raise the volume?
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
