Hi All,
So recently I've connected up an wideband O2 with narrowband simulation (Innovate MTX-L). I'm currently using the narrowband output from the wideband and connected to the factory ECU deleting the existing factory narrowband sensor.
To my surprise, the motor isn't idling at stoich which is strange it averages around 12.7 A/F when warm.
There are no vacuum leaks, no vented catch cans or anything as such, and I believe the coolant temp sensor is working because when it's disconnected the car won't start.
No real biggie, as I will be getting a standalone soon enough, but just curious on why the factory ECU runs so damn rich on idle? On full song at 0.7bar it drops to 10.5 A/F which is expected of a stock ECU.
This is the first time I've put a wideband to analyse A/F on a factory ECU, so I'm curious to see if that's correct? I always thought it should be idling on stoich, and even on light throttle/cruise the A/Fs are averaging at 13.3.
I might try cleaning the AFM this weekend and see if that makes any difference (I highly doubt it).
Any other ideas?
https://www.sau.com.au/forums/topic/429151-r33-rb25det-running-rich-on-idle/
are you getting these figures when the engine is cold or warm?
After a nice drive, thermostat is fully opened idle is at 650 rpm, I get about 12.7 A/F. On a cold start up I'm getting about 11.4 A/F. Like mentioned before, I'm not too concerned about it as I will be getting a new ECU soon enough.
Just more of a curious thing.
I can remember mine running rich with a stock ecu, used to puff out a little black smoke just reversing but was never a problem.
I'll try and disconnect the narrowband simulation to the ECU and see what it does. My original O2 was dead and was disconnected a few days after I bought the car due to idle hunts.
Instead of replacing a stock O2, I decided to for a wideband with narrowband simulation because I'm going to get a full standalone soon enough.
I'll try and recal the O2 too and see what's going on and also borrow my mate's handheld Innovate wideband and see what's going on.
Oh yeah and the sensor is mounted just before the Cat
Just for you Jonnie xxxooo
the wavy green is the o2 doing it thing, the spike is decal fuel cut.
Notice the lag between throttle V+ and RPM and LAFR, well that how long it takes for my Tech Edge to log what my foot is doing ;)
that lag time isn't too bad!
anyways, just something interesting, took my car on the track yesterday and the consumption was hideous!! :yucky:
84kms per 25L
flat foot down the straight on wakefield and she was 10.1 A/F
On another note, I did an ECU error code check, got error 13 = water temp sensor..
explains why it's overly rich!
Had a feeling the temp sensor was reading incorrectly, 10:1 is fairly normal for the top right corner of the stock fuel map. I've started slowly taking fuel out of mine there, and it's still in the 10.xx:1 range. Put my new 440CC EV14 injectors in tomorrow so I expect my economy will be shite for a couple of week while I attempt a home tune.
Haha too easy, injectors in rough tune done, made it home ok, beer O'clock time :)
lol.. isn't really rocket science right? just as long as you're getting the right A/F you'll be sweet.
    • They're so beautiful 馃槏
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I鈥檝e also seen them explode from the binding
