Gtr Performance Parts - Massive Sale - Have A Look!
I have a few parts left over from my parting out my car. All parts are 40 minutes south of Melbourne. Everything came off a running car.
$3000 RB26DETT engine which I only put 10,000kms of in the whole time I owned my car. It has only been run at 280rwkw on standard injectors. Made 300rwkw on the dyno at 100% duty cycle but I wanted to keep a safety margin. I imported it with N1 pistons which has been confirmed after I removed the sump recently. All bores look good. It alway had good oil pressure. I have attached pictures confirming the N1 pistons. I couldn't tell you which model crank or oil pump. It was an extremely smooth engine. I have the turbo manifolds, dumps and new gaskets in a box. Comes with everything pictured. Also comes with coil pack cover. Sump was cleaned while it was removed. Custom fan. I never had any overheating issues and increases power.
May sell the rocker/coil pack and cam cover, sump, coil packs $450, complete inlet and everything attached to it ?? seperately if the engine doens't sell as a complete unit soon. I know most people will only be buying it to replace a blown engine anyway hence already have all of these parts.
$1500 OS GIken full face solid centre triple plate clutch. 80-90% meat on clutch packs and no hot spots on the drive plates. It is very drivable as I've driven on it in city traffic etc. These are rated to 1000hp. One of the try perfomance clutches out there today. Worth $3000 new.
$650 324mm brake upgrade. UAS adapters. Braided lines with metal fittings. New slotted rotors front and rear. Reconditioned and painted calipers. Castor rod deflectors and if I can find it a master cylinder stopper. Also have several sets of 50% worn pads. DS2500, DS3000, EBC etc.
$175 R32 GTR airbox
$100 R32 radiator
$100 resistor pack for injectors
$100 R32 GTR alternator
$100 RB series starter motor
$100 R32 GTR engine loom to ECU
  • Replies 41
Front pipe is custom made to suit the custom made front pipes $150. 3inch dump/fronts into 3.5 Y pipe stepped down to a 3 inch aft flange. Might be sold though. In corresondance with another person via PM atm.
$150 for the cat back. Sick of stepping over this in my shed for the last 6 month!
  • 3 weeks later...
  • 1 month later...
 Share
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
