Hi there,
as my r34 25det neo spun a bearing last week, I am going to be building a 25/30.
I will be using the following parts in my build,
JE pistons 86.5mm
Spool RB30det rods
ACL race series bearings
Crank collar for oil pump drive
Nitto Headgasket
Supertech valves, guides, retainers, springs
Camtech 272' cams
Bosch 1000cc injectors
Garrett GT35r .82 rear
6Boost exhaust manifold
Slide Industries Intake plenum
I'm hoping for a reliable power output of around 500-550rwhp.
I am still searching for information on how people have disabled VCT, is it as simple as welding up the hole?
so if anyone has any information please share :)
Thanks
Corey
https://www.sau.com.au/forums/topic/429221-rb30det-build/
With the cams I'll be running I wont be able to run VCT anyway, as for the oil pump ill probably end up with a new standard rb25 pump with a billet gearset :)
thanks guys
Why not change the cams then, if you are only running a GT35R surely tomei type b 260s would be a good match and you can keep the VCT. I am looking into doing something similar. A few people on here seem to be getting great results from the HTA range of turbos in terms of better response and top end power compared to the standard garretts.
My RB25 Neo is running fine at the moment and I am looking at getting one of the HTA GT35Rs and putting that on and then later down the track building up an RB30 bottom end as the 35R might be a bit laggy on the standard 2.5, even being the HTA version. But from what I read the VCT is a good thing so just something to keep in mind, a lot of the guys in the RB30 conversion thread try to keep the VCT.
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6961931
That's exactly the same spec's as my motor
Accept mine has a standard bottom end & made 380kw at 17psi on 98octane.
keep in mind i had 3 broken ring lands at the time so loosing compression in those cylinders.
you should be able to crack way over 400kw easily.
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6965323
okay guys, well I have received my block and head back from the machinist, I have restricted both oil feeds in the block to 1.5mm feeds, the head has been ported and had a service with the new valves, springs, retainers, and cams. the block was bored to 86.5mm and drilled and tapped for the extra tensioner as well as a crank collar fitted.
I'll add some pics in the next few days :)
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6976704
Hi there, it will be used as my daily with the occasional track events, as for engine builders I'm not exactly sure where your from, RIPS always seem to build some porn looking motors but I've gone with a local engine builder so I'm not really familiar with who else is out there, usually a machinist shop is a good place to ask or your local import specialist will have a good idea
https://www.sau.com.au/forums/topic/429221-rb30det-build/#findComment-6990751
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
