Hi there,
as my r34 25det neo spun a bearing last week, I am going to be building a 25/30.
I will be using the following parts in my build,
JE pistons 86.5mm
Spool RB30det rods
ACL race series bearings
Crank collar for oil pump drive
Nitto Headgasket
Supertech valves, guides, retainers, springs
Camtech 272' cams
Bosch 1000cc injectors
Garrett GT35r .82 rear
6Boost exhaust manifold
Slide Industries Intake plenum
I'm hoping for a reliable power output of around 500-550rwhp.
I am still searching for information on how people have disabled VCT, is it as simple as welding up the hole?
so if anyone has any information please share :)
Thanks
Corey
looks like a good list to achieve what you want.
not sure on the VCT.
alot of people like it.
if you can get it to work, would be better for daily duties.
With the cams I'll be running I wont be able to run VCT anyway, as for the oil pump ill probably end up with a new standard rb25 pump with a billet gearset :)
thanks guys
Why not change the cams then, if you are only running a GT35R surely tomei type b 260s would be a good match and you can keep the VCT. I am looking into doing something similar. A few people on here seem to be getting great results from the HTA range of turbos in terms of better response and top end power compared to the standard garretts.
My RB25 Neo is running fine at the moment and I am looking at getting one of the HTA GT35Rs and putting that on and then later down the track building up an RB30 bottom end as the 35R might be a bit laggy on the standard 2.5, even being the HTA version. But from what I read the VCT is a good thing so just something to keep in mind, a lot of the guys in the RB30 conversion thread try to keep the VCT.
That's exactly the same spec's as my motor
Accept mine has a standard bottom end & made 380kw at 17psi on 98octane.
keep in mind i had 3 broken ring lands at the time so loosing compression in those cylinders.
you should be able to crack way over 400kw easily.
okay guys, well I have received my block and head back from the machinist, I have restricted both oil feeds in the block to 1.5mm feeds, the head has been ported and had a service with the new valves, springs, retainers, and cams. the block was bored to 86.5mm and drilled and tapped for the extra tensioner as well as a crank collar fitted.
I'll add some pics in the next few days :)
Hi there, it will be used as my daily with the occasional track events, as for engine builders I'm not exactly sure where your from, RIPS always seem to build some porn looking motors but I've gone with a local engine builder so I'm not really familiar with who else is out there, usually a machinist shop is a good place to ask or your local import specialist will have a good idea
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
