wait for someone to confirm. i can't recall exactly, but i think you need 3/4UNF-16 to the block. Which it seems is the one you linked.
Alright. Well I guess its time to play the waiting game.
yep it will fit
Alright. Thanks for the confirmation :) Now going to try and install the sensor that came with the gauge because according to the instructions sandwich plate is not necessary :S
No to the RIGHT of the rear knock sensor in the photo. You can just see the plug, its a bit hard in the flat black finish but best I can do, cant seem to circle it in photobucket
Don't have a build thread, been thinking about it, but to lazy so far :)
Its only a GTS-t
Its only a GTS-t
I edited it with paint. Do you mind doing that please because I'm a little loss with terminology :S
Ye man your car looks like a GTR ey.
In this spot here?
What size is it? Wouldn't happen to be the standard 1/8?
Is this a good location to get oil pressure readings from?
If so, saves the trouble of a sandwich plate.
I'm guessing there would be no oil pouring out during installation either, yeah?
Yes that is it, It is 1/8 BSP on the block
It is there for cars not fitted with an oil cooler, I'm not sure if theres any in the RB25 range but It's there if there was ever a day that this was the case.
Won't need to drain oil to install a sensor there, you will only lose whatever oil was in the gallery at the time. So if you leave the engine overnight most of the oil should have drained out of that section
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
    • Welcome. Do you plan to race? Or is this more of a weekend toy?
