wait for someone to confirm. i can't recall exactly, but i think you need 3/4UNF-16 to the block. Which it seems is the one you linked.
Alright. Well I guess its time to play the waiting game.
yep it will fit
Alright. Thanks for the confirmation :) Now going to try and install the sensor that came with the gauge because according to the instructions sandwich plate is not necessary :S
No to the RIGHT of the rear knock sensor in the photo. You can just see the plug, its a bit hard in the flat black finish but best I can do, cant seem to circle it in photobucket
Don't have a build thread, been thinking about it, but to lazy so far :)
Its only a GTS-t
Its only a GTS-t
I edited it with paint. Do you mind doing that please because I'm a little loss with terminology :S
Ye man your car looks like a GTR ey.
In this spot here?
What size is it? Wouldn't happen to be the standard 1/8?
Is this a good location to get oil pressure readings from?
If so, saves the trouble of a sandwich plate.
I'm guessing there would be no oil pouring out during installation either, yeah?
Yes that is it, It is 1/8 BSP on the block
It is there for cars not fitted with an oil cooler, I'm not sure if theres any in the RB25 range but It's there if there was ever a day that this was the case.
Won't need to drain oil to install a sensor there, you will only lose whatever oil was in the gallery at the time. So if you leave the engine overnight most of the oil should have drained out of that section
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
