wait for someone to confirm. i can't recall exactly, but i think you need 3/4UNF-16 to the block. Which it seems is the one you linked.
Alright. Well I guess its time to play the waiting game.
yep it will fit
Alright. Thanks for the confirmation :) Now going to try and install the sensor that came with the gauge because according to the instructions sandwich plate is not necessary :S
No to the RIGHT of the rear knock sensor in the photo. You can just see the plug, its a bit hard in the flat black finish but best I can do, cant seem to circle it in photobucket
Don't have a build thread, been thinking about it, but to lazy so far :)
Its only a GTS-t
Its only a GTS-t
I edited it with paint. Do you mind doing that please because I'm a little loss with terminology :S
Ye man your car looks like a GTR ey.
In this spot here?
What size is it? Wouldn't happen to be the standard 1/8?
Is this a good location to get oil pressure readings from?
If so, saves the trouble of a sandwich plate.
I'm guessing there would be no oil pouring out during installation either, yeah?
Yes that is it, It is 1/8 BSP on the block
It is there for cars not fitted with an oil cooler, I'm not sure if theres any in the RB25 range but It's there if there was ever a day that this was the case.
Won't need to drain oil to install a sensor there, you will only lose whatever oil was in the gallery at the time. So if you leave the engine overnight most of the oil should have drained out of that section
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
