So many times I read threads on SAU about additions to the OEM RB26 ignition system, yet no one has completely or conclusively understood the capabilities of the std ignition system, I have made 500kw at all 4 tyres with std ignition at 0.024". Yes I have also fitted a HKS DLI which by the way does not increase you max secondary ignition voltage, it increases the current, and the engine does run a cleaner spark plug
So the question that needs to be answered is why can some Rb26 run extreme power levels and others can not with the std ignition?
Simply because the ignition is breaking down, but where, so following test will identify your ignition problem.
1, Firstly you will need 6 x brand new plugs gapped to 0.6mm, 6 x sachets of high temp dielectric silicone greese (jaycar sells it) an aluminium sheet about 800 x 400 x thickness does matter, but say 1,0mm, you will need to drill a 9mm hole in the top left hand corner of the shortest side
2. Ensure ignition is OFF, Remove ignition coil loom from coils, remove coils from engine, eg 2 off x 3 coils in Al coil mounting brks, remove std ignitor from engine cover, remove old spark plugs, liberally apply dielectric silicone greese to the top and insulation of each new plug and install into engine
3. Remove 6 x injector connectors,
4. Remove crank angle sensor clip, ensure you witness mark around the washers of the 3 x crank angle bolts before you loosen and remove crank angle sensor from the motor, connect the crank angle sensor back onto the crank angle and rest it in a safe place loosely
5. Plug ecu & coil looms back into ignitor (which has been removed from engine cover), find 1 x small nut for ignitor bolt so that you can attach the std ecu ignitor earth onto the ignitor in std position
6. Place the Al sheet directly on top of the engine with longest edges running front to back, with the 9mm hole at the back on the drivers side
7. Place sideways down the 2 off 3 x coil packs on the Al sheet in simular position as if they were fitted to the engine
8. Find a 8mm nut and use 1 x 8mm Al coil mounting bolt to securely bolt the engine ignition coil loom earth to the Al sheet using the 9mm hole that you drilled (this earth normally attaches at the back on the head under the ignitor)
9. Now connect the ignition coil loom to all 6 x ignition coils
10, Install 6 x old spark plugs to ignition coil boots, and space up coils with steel or Al, so that all spark plug threads are touching Al sheet
11. Connect 1 x start jumper lead from neg battery terminal and connect to Al sheet
12. Turn ignition ON
13, Ensure you are well clear of the spark plugs, spin the crank angle sensor by hand to stimulate the ignition to operate (spinning crank angle sensor in the wrong direction will not operate the ignition, it must be spun in the alternate direction)
14, Testing the ignition system can occur by ensuring the Al coil mounting brkt is in contact with the Al sheet whilst you increase the distance of the spark plug thread from the Al sheet, this should be done in limited illumination to see the arc bridging, if, and where it is occuring
A good std ignition system will ionise approx 25mm air gap between spark plug thread and the Al sheet, if the gap is increased further until the coils can not fire down onto the Al sheet, the 2 off x Al coil brkts with there 3 off x coils each will only " jump" on Al sheet with no arc bridging - Ignition System Test Complete and PASS
But generally ignition misfires are caused by bridge arcing across between the top of the spark plug silicone boot connection point on coil to the ferritic iron core coil mounting plate (its on the coil with the 4 holes in it) Eg From the top of the silicon boot, across the coils body to the coils mounting frame.
Once the coils that are bridge arcing have been identified, you must remove the spark plugs and the silicon boots from these coils and retest to ensure that the coil spark initiates from the coils high tension terminal and not from a crack or pin hole in the coils housing, if this is the case it is in the bin and buy a new coil, but if it is not, what you need to do now is remove all the bridge arcing coils from there mounting positions, get a sharp stanley knife and a very good light source to closely examine the coil body silicon boot connection point for carbon tracking(some form of magnification will help with this task), and use the blade to scrap away on the coil housing until all the carbon tracking marks (ie very small thin black tracks) are removed, when done (be matriculus when you make final inspection) clean all 6 x coils with electrical spray solvent, all 6 x silicon spark plug boots are to be wash with soap and a "clean engine oil gallery brush"(suitable size one of coarse and scrub the silicon boots clean ) and finish with electrical spray solvent
Apply liberally the dielectric silicon grease to all the coil silicon boot connection points and to the top of all the silicon boots and connect the silicon boots back onto the 6 x coils and retest as above.
The final test of approval is when you can spin the shaft on the crank angle sensor and there is "NO" arc bridging when the spark plug threads are further away from the Al sheet than the spark can jump (eg >25mm approx) and all that happens is that the coils/brkts will jump a little, you also may see a very small spark coming from the coil mounting brkt to the Al sheet, this is the residual emf when you are shunting the in this test, now you can put it all back together with your new spark plugs and enjoy.
In closing
THE SECRET - CLEANLINESS AND A LIBERAL AMOUNT OF GOOD HIGH TEMP DI-ELECTRIC SILICON GREASE
All RB26 coils (even New one's) should use High Temp dielectric silicon grease on the coil/silicon boot connection point
New Nissan OEM coils are the best
Always wash, clean, liberally apply silicon grease to silicon boots when changing new spark plugs
Always apply dielectric grease to the top of the plug and insulator on new plugs
Ensure the ignition coil loom earth is in good condition and firmly connected and the 6 x ignition trigger ecu loom earth is connected to the ignitor
Ensure all 6 x ignition coil + positives are getting battery voltage (consider dedicated ignition relay direct battery feed)
Ensure main earth battery lead that goes to engine block which also connects to the car body half way along is connected and that the body earth is clean, and tight(This is a strategic point for a number of electrical problems).
ALL THE ABOVE AT YOUR OWN RISK
Edited by rockvale
https://www.sau.com.au/forums/topic/429309-rb26-ignition-misfire/
Hi,
An interesting article, the best one I have so far! I have just upgraded to small 2860 -7 turbos and increased the boost to about 15 - 16 psi. Occasionally around 5000 rpm I get a misfire. It feels like ignition and occurs around maximum engine load.
I like the idea of your test jig! It looks like you are creating another ground reference with the aluminium sheet and increasing the gap between the spark plug thread until a spark jumps somewhere else. Do you have any photos of the setup, this would be handy!
A quick question on the injector plugs, do you just pull them off, or remove the spring first?
Cheers
Rob
Edited by Blk33
Yes very interesting test..
but regarding your miss my tuner (Soichi at ST Hitech) pointed out a miss at high revs/boost and told me to replace the copper plugs with PFR7 plugs gapped to 0.8mm so maybe that would be worth a try first.
Hi,
Cheers
Rob
Hi Everyone,
I had a go this week following the information and it worked a treat for me.
I documented the process and uploaded it to YOUTUBE. Have a look and see what you think!
Thanks to rockvale for the insite.
Rob
Hi,
Cheers
Rob
  • 2 months later...
The specifications for dielectric grease show about 20,000 volts is required to jump a 1 mm length of dielectric grease.
So by covering the top of the spark plug in dielectric grease it makes it easier for the spark to jump across the spark plug gap rather than across the outside of the spark plug.
I agree with SiR_RB on reflection, maybe leave the top of the spark plug free of grease, however as long as a good metal contact is made with the top of the spark plug, covering the top of the spark with grease will not be a problem.
Greasing up parts inside the combustion area is a cool idea.... And it seems to work.
I hadnt jimmied much else on my car so I bought a better ignition system and solved my misses. Good to 1000hp (though I'm far from this) and 1.4mm gaps now (running 1.2mm at this time). Bazinga
Edited by NismoSTune
Where's the best place to buy the dielectric grease?
I saw the one at jaycar but it was called "conductive carbon grease", was not sure if this was the right one??
I bought dielectric grease from: http://www.parts4.com.au/
Dielectric grease is an insulator, conductive carbon grease is not what you want, it is a conductor!
I melted a set of iridium plugs a while back, they were 3mm gap at least and my car only just started misfiring in the top end at 30psi. VQ coils are just better designed I think, not necessarily higher voltage but less chance of the spark jumping to earth as the rocker cover is plastic, there is nowhere for the spark to earth other than the plug gap.
There is no reason a little ingenuity couldn't get RB coils jumping a similar gap...
    • Good news!!! Changed the O ring today and Iโ€™ve got the โ€œpssshhhhโ€ back when I open the fuel cap ๐Ÿ˜‚๐Ÿ™Œ๐Ÿผ๐Ÿ™Œ๐Ÿผ It was 100% the O ring because that bloody thing was inside the fuel tank ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But sheโ€™s running!!! โค๏ธ
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though egย https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
ร—
ร—
