Here is the back story:
I had the timing belt tensioner stud break while the engine was running. My engine had a few bent valves as a result.
I had a freshly rebuilt R34 head sitting on the shelf that I was saving for an RB30 build. It found its way into my R32. I used the R34 cams and swapped the R34 cas too.
The problem:
It only makes about 1/2 the boost that it should. It also sounds odd. It sounds like the timing is wrong.
Is there a difference between the R32 and R34 timing marks? Do I need to remap for the R34 head and cams? Or something else?
https://www.sau.com.au/forums/topic/429339-r32-wr34-head-not-boosting/
It is a stock R32 RB26 block. The manifolds are R32. I have replace the head, cams, and cas with parts from an R34 RB26. The head was rebuilt by a very experienced head builder. I rewired the cas plug to suit the R34 cas. I used a new oem head gasket. I also put in head studs while the head was off.
It's probably not relevant, but I also has an R34 crank, oil pump, and turbos installed. These upgrades were done a few years ago, and shouldn't have any effect.
I think that covers everything!
I think my first post was a little confusing. I didnt use an RB30 block. I bent some valves. Rather than replace the valves, I replaced the entire head with one that I was saving for a different build.
Edited by DanShirts
According to your link the compression ratio would be exactly the same across all GT-Rs.
There is a difference in valve timing (not lift or duration) according to this Tomei chart but I don't know if that would halve the boost:
http://www.tomei-p.co.jp/_2003web-catalogue/e090_camshaft-specs.html
