As above, seems when ever I'm having fun I get fuel surge even with half a tank of fuel. Has anyone installed a surge tank to the stagea's, I only suffer this when right hand down I'm yet to try left hand down
What do you mean by fuel surge? Are you losing power? I have a surge tank as it happens but never suffered from " fuel surge " before I installed it (or after). A surge tank is only necessary when you are tracking it with a near empty tank. I would say you have another problem. Changed your fuel filter lately or perhaps your pump is on the way out?!
Having said that your pickup is on the rhs so it is logical that the pickup is more likely to be exposed when turning right. Maybe your pump has not been installed correctly and the arm with the sock is not flat on the floor of the tank.
Are you running stock pump still ??
Surge tanks are insurance policy ,not just when tank is near empty but at any stage. By the looks of it you like having fun in the stag, I'd be checking filters including sock filter on pump and while you got it out change the pump to a deutchwerks Intank or walbro and give it a direct battery feed so 12v+ switched of course ,and if ya looking to mod in the future chuck a surge and external pump on when ya do :)
mmmm guys I'm very well away of doing things properly, and I am able to diagnose fuel surge! I was more interested in if people suffered from it and what they needed to do to fix it, where and how the installed a surge tank,
I also competed in a motorkhana and experience the same problem with right hand down (so it's obviously a problem with fuel to the pick up)
and it's very easy to do burnouts in a stagea. Drive in at 40 , clutch in handbrake side step hold on!
How did u get ur 260 to do a skid, i would say ur problem lays there. Ghetto wiring, and a shit fuel filter all add to the drama.
Tunes, cooler pipe leak, the list is endless untill you corner where the problem is.
Ghetto wiring lol
Well here's my surge tank but I don't suggest you copy it. As its in a station wagon there is no boot compartment. I have made a metal cover which has sound absorbing material inside and outside but my Bosch 044 is still very noisy. If I were to do it again I would either put the surge tank under the body in front of the petrol tank or preferably get a tank made up with a home for the fuel pump(s) built below tank level so its all in one and you don't need a lift pump.
where and how they installed a surge tank,
getto wiring, you guys are muppets! so before you make you stupid comments, not all people do dodgy's and some people can drive in a small area and whip donuts in 4wd with no problems, especially in a massive fridge.
In saying that towards the end the 4wd light came on, which obviously stop putting power to the front wheels believe it was from when the car got fuel surge. waited turned the car off at the end, turned it on again and it's been fine since
that doesn't show the roll in , but as you can see before the surge it was spinning as it would in 4wd
Thanks KiwiRS4T that's a start for me to have a look and work out where to go! I was going to look at in rear drivers side compartment, see if there is enough room around the atessa pump, see if could get a surge tank made to fit in there. or in the spare tyre area, get something fab in there, but like you said, main concern is it's a family car (Children in it regularly) that if we have a rear car accident I wouldnt want that to well you know what im saying.
Regards
Fuel pressure reg, I don't think that's going to help here. Id smash some new filters in Lars, its a cheap way of eliminating one thing. Then throw a big boschy in!
Sif not skid a stagea guys, fark.
I can see this car going bang soon ! You can fit a small surge behind petrol tank at the back very neatly. Still looks like your only rwd in the skid as you stop and start doing donuts from a stationary start or was that when your your 4wd light was on ? Grab your self a tcs controller and you can manually dial in ya front and rear split and save ya altessa system .
  • Like 1
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
