Hey guys,
I'm currently doing some work in my 32 gtst up in Brisbane, I entered the part number off my afm into google, and it came up with pictures and info on rb25de afm's??
I thought the only upgrade was the Z32?
I do have an extra afm that I got with the car (entered into google came up rb20det afm)
So, just wondering if I should put the oem rb20 one in?
And just sell the rb25de or keep it on, depending whether it is an upgrade..
Sorry I did try searching but couldn't find anything regarding this.
Cheers.
https://www.sau.com.au/forums/topic/429366-found-an-rb25de-afm-on-my-r32-gtst/
According to PaulR33's PDF there isn't really an AFM specific to DE and DET? That may be wrong though, i am not 100% sure.
Match up your part number with one from his site.
http://www.paulr33.com/diagrams/airflow-meter-wiring.html
if it works fine just leave it there! the extra afm you got with the car maybe borked hence the de afm replacement . a few parts same on rb25de and rb20det including the injectors
It does work fine. So I was thinking of just leaving it, BUT the reason is..
The rb20 afm I got with the car had a receipt for $187 about 11days prior to me buying the car.
So I guessed he bought it to replace the rb25 one (maybe he was as clueless as me?)
If you wanna give me the part numbers, I can run them through FAST and see what vehicles they suit. :)
That would be great.
Unfortunately I am back on the coast for work until this weekend and did not write part numbers down.
Okay ended up finding the part number for the AFM that is currently ON my rb20det
- 22680-02u00
This is the one that comes up as the RB25DE AFM
Edited by Zrobe
Guest
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
