Hey guys,
I'm currently doing some work in my 32 gtst up in Brisbane, I entered the part number off my afm into google, and it came up with pictures and info on rb25de afm's??
I thought the only upgrade was the Z32?
I do have an extra afm that I got with the car (entered into google came up rb20det afm)
So, just wondering if I should put the oem rb20 one in?
And just sell the rb25de or keep it on, depending whether it is an upgrade..
Sorry I did try searching but couldn't find anything regarding this.
Cheers.
https://www.sau.com.au/forums/topic/429366-found-an-rb25de-afm-on-my-r32-gtst/
According to PaulR33's PDF there isn't really an AFM specific to DE and DET? That may be wrong though, i am not 100% sure.
Match up your part number with one from his site.
http://www.paulr33.com/diagrams/airflow-meter-wiring.html
if it works fine just leave it there! the extra afm you got with the car maybe borked hence the de afm replacement . a few parts same on rb25de and rb20det including the injectors
It does work fine. So I was thinking of just leaving it, BUT the reason is..
The rb20 afm I got with the car had a receipt for $187 about 11days prior to me buying the car.
So I guessed he bought it to replace the rb25 one (maybe he was as clueless as me?)
If you wanna give me the part numbers, I can run them through FAST and see what vehicles they suit. :)
That would be great.
Unfortunately I am back on the coast for work until this weekend and did not write part numbers down.
Okay ended up finding the part number for the AFM that is currently ON my rb20det
- 22680-02u00
This is the one that comes up as the RB25DE AFM
Edited by Zrobe
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
