Hey guys, newbie here! Sorry my first post is with a problem...I've search functioned this problem on here and haven't been able to find any new solutions as yet...
So here's the story. Since I bought my Stag ( C34 S2 RWD Auto) it's been having an intermittent misfire problem; the first I noticed was that on startup the Check Engine, TCS Off and Slip lights were all coming on. There was also a vibration I could feel through the steering wheel, felt like a slight misfire.
When I first bought it the guys from Redline told me it had been having this problem, but that they had replaced coil packs and plugs and it hadn't happened since. Well, it was still happening.
Since then I've taken it back several times, had the O2 sensor and AFM changed and a wiring loom problem fixed. The problem is less regular now but still happening, and if anything it feels like the misfire is getting worse (vibrations through the whole car now getting worse).
The misfire seems to go away after about 15 minutes of driving, but the TCS and Slip lights stay on (I assume this is because the ECU hasn't reset yet). At first I thought it was only happening when the engine was relatively cold, but a couple times now it's started missing halfway through a 30min drive.
When the miss is bad I can stand outside the car when it's idling and hear a popping from the exhaust. Driving-wise, when above about 2500rpm the problem seems to go away but there's a definite reduction in power. At idle through to about 1500rpm seems to be the worst, and it seems to resonate badly at a throttle position just above neutral throttle (exhaust resonating I think, as it vibrates through the rear of the car).
When throttle is applied in neutral, the problem isn't as bad as when driving. The vibration only really occurs at idle when it's in neutral.
I'm taking it back in again tomorrow to get the ECU checked out, but any ideas would be appreciated.
TL;DR version:
C34 RWD Auto: Intermittent misfire + check engine lights. Coil packs, plugs, O2 sensor and AFM replaced, wiring loom problem fixed. Still happening.
Edited by powerhearse
https://www.sau.com.au/forums/topic/429369-intermittent-misfire-problem/
Are they brand new or what they had in the garge/workshop. I had the same problem less the light on dash replaced with 2 sets of coil packs from this mechanic, cracked the shits went and bought splitfires and has never happened again in 7 months.
Yeah sounds like could be cool packs , but check engine light should not be on . When you take it to them ask them what fault codes Ecu is throwing up and get them to reset .
I've run both splitfires and yellow jackets both are good coil packs
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
