As you are new to Turbo's, it may be worth pointing out that an Atmospheric BOV will potentailly make your car run like arse as 33s are designed to have the BOV plumbed back into the system.
Having said that, a mate of mine has one of these on a pipe and may be willing to sell it...
I have one that you can have complete with the pipe including the flange for $50 plus postage.
Here are a few pictures
Please PM me if you are interested.
When you say run like arse what do you mean by that? How much would he be willing to sell it for?
Dont do it!
Factory plumb back BOV only.
Do some research into how turbo AFM based engines work.
Changing to an atmospheric BOV will make the car run like shit as said above.
Dont do it!
Mr. Kitto since it seems you know what your talking about why don't you educate me? :P
The air that has been measured by the airflow meter is released to atmosphere instead of back into the system.
The ecu (computer) has read that air and added fuel to match the air.
So the engine can stall when you clutch in as now there is too much fuel.
Plumbed in bov keeps the air in the system, so all is well.
This.
If you really really want an atmospheric BOV (I dont know why because they attract attention and are soo cheesy and wanky) then you will need to move your AFM cold side of the intercooler and have the BOV located a fair distance up stream of the AFM. When you move the AFM youll need a proper retune.
Moving the AFM doesnt always work either.
Or switch to a MAP sensor based ECU.
Best option? Retain the factory one.
Alright great thanks for the info. Didn't know that So what type of aftermarket BOV is plumbed in?
This.
Nuh it's all good. I didn't know there were different types of BOV to be honest. But thanks for the explanation, but I'm good :)
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
