Hi all,
I am running an RB25DET Neo in my R32 and using the R34 power steering pump and reservoir. I have added a power steering cooler into the low pressure return line as can be seen in the pictures but apart from that it is exactly the same as factory.
The problem i am having is that i think i have a huige airlock in the system. My power steering pump is making some terrible noises and my mechanic mate said that it is trying to pump air through the system and tats wy it sounds like that. I am inclined to believe him as i had the whole power steering system apart when i took the engine out and it had absolutely no power steering fluid left in it when i put it all back together, so it seems i had perfect conditions to create and airlock in the system.
Many tutorials say to jack the car up, pour the P/S fluid in the reservoir and then turn the steering wheel from lock to lock and just let the system bleed itself and work the air out, but this is not working for me at all. Even with the wheels in the air there is resistance when trying to turn the steering wheel. And obviously it is even harder with the wheels on the ground. With the wheels in the air i have turned it lock to lock probably 200 times and it seems to make no difference at all to how it behaves. My mate said that there could be a bleed nipple or something similar on the power steering rack itself that i can use to bleed the system but from doing a little searching nobody has ever made mention of a bleed point on the power steering rack itself.
The only theory that i have at the moment is that it is my power steering cooler causing the airlock. I will get some photos tomorrow of how i have it set up, but basically i have it upside down in the front bar (ie, the power steering lines run up to it to connect to the barbs rather than down to it)
Any help ideas would be greatly appreciated as i am really a bit stumped at the moment. I don't want to have to drive it round to work the air out as it is making some truly terrible sounds at any revs haha :|
https://www.sau.com.au/forums/topic/429376-power-steering-issues/
No i have not, and that is what i am guessing the issue might be. The lines run up to the cooler and not down from it, as you can see in my highly accurate MSpaint drawing.
Red is rad support, grey is flat bar attaching cooler to support, black is cooler and green is the power steering hoses.
Unbolted it from the rad support, turned it up the correct was and lowered it as far as possible and then tried to bleed the system as per normal. Of course with my luck i ran out of P/S fluid and didnt have anymore to keep filling it. But even just doing that if feels so much easier to turn the wheel and the pump has stopper making the horrible noises that it was making before.
So it seems that even though it wasn't the highest point in the system it just didn't want to bleed.
Will fully fill/bleed the system and report back if it's fully fixed :)
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
