Hi all,
I am running an RB25DET Neo in my R32 and using the R34 power steering pump and reservoir. I have added a power steering cooler into the low pressure return line as can be seen in the pictures but apart from that it is exactly the same as factory.
The problem i am having is that i think i have a huige airlock in the system. My power steering pump is making some terrible noises and my mechanic mate said that it is trying to pump air through the system and tats wy it sounds like that. I am inclined to believe him as i had the whole power steering system apart when i took the engine out and it had absolutely no power steering fluid left in it when i put it all back together, so it seems i had perfect conditions to create and airlock in the system.
Many tutorials say to jack the car up, pour the P/S fluid in the reservoir and then turn the steering wheel from lock to lock and just let the system bleed itself and work the air out, but this is not working for me at all. Even with the wheels in the air there is resistance when trying to turn the steering wheel. And obviously it is even harder with the wheels on the ground. With the wheels in the air i have turned it lock to lock probably 200 times and it seems to make no difference at all to how it behaves. My mate said that there could be a bleed nipple or something similar on the power steering rack itself that i can use to bleed the system but from doing a little searching nobody has ever made mention of a bleed point on the power steering rack itself.
The only theory that i have at the moment is that it is my power steering cooler causing the airlock. I will get some photos tomorrow of how i have it set up, but basically i have it upside down in the front bar (ie, the power steering lines run up to it to connect to the barbs rather than down to it)
Any help ideas would be greatly appreciated as i am really a bit stumped at the moment. I don't want to have to drive it round to work the air out as it is making some truly terrible sounds at any revs haha :|
https://www.sau.com.au/forums/topic/429376-power-steering-issues/
No i have not, and that is what i am guessing the issue might be. The lines run up to the cooler and not down from it, as you can see in my highly accurate MSpaint drawing.
Red is rad support, grey is flat bar attaching cooler to support, black is cooler and green is the power steering hoses.
Unbolted it from the rad support, turned it up the correct was and lowered it as far as possible and then tried to bleed the system as per normal. Of course with my luck i ran out of P/S fluid and didnt have anymore to keep filling it. But even just doing that if feels so much easier to turn the wheel and the pump has stopper making the horrible noises that it was making before.
So it seems that even though it wasn't the highest point in the system it just didn't want to bleed.
Will fully fill/bleed the system and report back if it's fully fixed :)
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
