Sorry to hear it....
Argo rods too, bummer. I'm running Argo's in mine so hopefully I don't meet the same fate!
I've seen crank oil galleries blocked from a ball of sealant that has fallen off the sump to block join over time. It's very easy to overdo it went applying it.
Other than that the fact that it happened on cruise is a worry. Hopefully there is a clear cut reason as it sucks arse when a motor dies and you don't know why!
Im going to pull the oil pump apart today, but i was still getting normal pressures, so I doubt its the pump. Only about 2,000 miles on her since the rebuild. Havent even turned up the boost :( I was fun as hell at 12psi though.
Edited by ZT-R
I wouldnt think it would get any better the a R.I.P.S. build. Everything is out now, so its no longer a rips :( Anyone can assemble them, but not to his specs and attention to detail, Although I think i will debur the inside of this block, its ugly and quiet scary looking.
The number one piston is out of round by 8 thousandths. and the crank is egged. So for sure needs a new crank and rod.
Anyway, more disassembly pics.
IMO the mains dont look great, but its hard to tell from pics, the fact all the big ends are trashed points to oil issues, could there be contaminants in the cooler etc? have you asked rips? Theres not somthing funny like oil thermostat or oil filter block incorrectly plumbed? how do the cams look?
Edited by Adriano
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
